$8,000 need ideas/help!! 460
I have $8,000 to use for a 1991 F-350 Super Duty dually 4x4 with a 7.5L 460 Automatic Transmission. I will be doing lots of heavy duty towing and would like ideas for performance parts that will give me the most torque, towing capability, and fuel economy for my $$$. And no I will not be buying something else because I just want to work with what I got and I really like this generation of F-350 anyways.
Already in consideration
-Banks Power Pack
-Under/Overdrive
Thanks
-Banks Power Pack
-Under/Overdrive
Thanks
FOUR WHEELER Magazine's Project M.P.G.
Look here for a good list of bolt on performance stuff. Not sure what the total would come to today, but shouldn't be near $8,000.
If you're planning on any significant upgrades to the motor, I'd look into a MAF conversion.
-Banks Power Pack
-Under/Overdrive
Thanks
-Banks Power Pack
-Under/Overdrive
Thanks
it is a superduty...and a 7.3 IDI even with a turbo would be noncomparable to the 460 with the aftermarket parts I've looked at...only a Powerstroke would do, but that cost I see being greater than 8,000 as I would have to swap out most everything in it for the diesel counterparts.
just checked the site...good idea, but the only cummins that will produce enough torque for it to be beneficial (stock) are the 2003 or earlier models which are running $7000-$9000 for a rebuild plus parts that still need to be transfered into the Ford which would be at least another $1000...I guess it help if I told you I was looking for 520-600 ft torque. HP I could really care less about...to an extent
Used 12 Valve $1500
NV 4500 $1000
Engine mods $2000
Clutch $800
Misc Items $1000 maybe a T case or adapters
Total $6300 give or take some.
Anyway, maybe you know all this and I am just like one of those people that knock on your door on sunday afternoon trying to spread my beliefs. Either way, I hope that whatever you decide to do, you have fun with it.
well you do make a good point about that, but swapping to a diesel I think will have to be a summer project unfortunately. But in the long run it would be the better choice for sure. And the power I need for sure. I guess I'll have to hold on to my ***** and $$$ and...wait which is always my problem .
Well...... I guess just based on what I have seen stuff sell for and what I would pay for it. It does depend on someones definition of "decent" A cummins with 150,000 miles on it to me is still very decent, provided it didnt spend half its life running down the dragstrip or any other abuse. You know the longevity of those motors, especially the ones that stayed stock their whole lives. Anyway, with that being said, a second gen 12valve sold on craigslist near me a few weeks ago for 1600 bucks, it had 165,000 on the clock. I have not seen a used GM or Dodge NV4500 go for more than $1000 bucks unless it was from somewhere like NV4500.com, which they are 1600 brand new, of the owner had just rebuilt it and fixed the 5th gear nut. Anyway, a used NV4500 should be 1000 or less, I think
The transfer case and or adaptor issue. Well we could back up and he could go with a ZF tranny but I think the adapter for about 700 plus a modded dodge flywheel for I dont know how much. Or he could go with the 94 newer dodge t case, driverside drop which I dont see why that would be worth more than $1000.
Maybe I am on crack, or maybe I just buy junk..... but I hope that I havent mislead anyone into thinking its cheaper than it is. I read an entire 12 valve swap thread into an 86 Chevy and it cose the kid $9000, but he bought some things that I would have built instead, like crossmembers and such. Anyway, I know that you could spend as much on a swap as you wanted or try and be a little more conservative. I am cheap. One good idea would be to find a donor truck that has everything already, may be cheaper. Thats what I did for my ZF 5 swap... One wrecked 1989 F250 5 speed, $350. The ZF 5 and all the swap parts are worth a whole lot more together.
One more thing, he could go with an intercooled 1st gen cummins which are cheaper and still get good torque out of it.......
Just so you know. Ford never made a 4wd f-superduty. A company converted a handfull of them but finding one is worse than a needle in a hay stack.So i would say you have a 4wd 350. And i would rethink not putting a powertsroke or a Turboed idi in the truck. The idi w a turbo can make a honest 250 reliable HP and have gobs of torque. The powerstroke stock makes 225 HP and alot of torque. And both will get 13-15 mpg(empty). Once you toying w the 460 you will get 6-9 mpg and no the amount of torque the diesel put out.
