2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Max Load for factory installed roof rack?
Old 04-14-2010, 12:31 PM
avesterg's Avatar
avesterg
avesterg is offline
I searched thru the owner manual, but couldn't find any reference to the maximum load allowable on the factory installed roof rack on my 2007 Expedition. I want to buy a 21 cu ft roof-top carrier, and want to make sure that the factory rack system can handle the weight/load.
Anybody know? Thanks!
Old 04-14-2010, 03:59 PM
berry1234's Avatar
berry1234
berry1234 is offline
I would guess 300-400 pounds total. I think the rood would start to buckle/dent before the plastic snapped though.
Old 04-14-2010, 04:06 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
pretty sure it says right on the rails 150 lbs. wife has the Expy right now so I can't check for you.
suggest you take a quick look
Old 04-14-2010, 05:00 PM
gddyup's Avatar
gddyup
gddyup is offline
I just ran outside and looked at mine. I can't find a sticker or label that gives me any info whatsoever for the factory roof rack....
I would guesstimate that each rail will be rated around 100 pounds. I have instaled roof racks on a number of Toyota/Lexus SUVs before and each rail was rated in that area.
I did a google search for the Ford rack but didn't find anything worthwhile....
Old 04-14-2010, 05:50 PM
chuck s's Avatar
chuck s
chuck s is offline
LUGGAGE RACK
Your vehicle is equipped with a roof
rack for transporting items on the
exterior of the vehicle. The
maximum recommended load to be
carried on the roof rack is 200 lbs
(90 kg), evenly distributed.
The
cross-bars can be adjusted by using
the thumbwheels at each end. Use
the tie-down loops on the
thumbwheels to secure load.
To adjust the position of the
cross-bar (if equipped):
1. Loosen the thumbwheel at both
ends of the cross-bar (both
cross-bars are adjustable).
2. Slide the cross-bar to the desired
location.
3. Firmly retighten the thumbwheels
at each end of the cross-bar.
Be sure to check that the thumbwheels are tight each time load is added
or removed from the roof rack, and periodically while traveling.
Always ensure that the load is secure before traveling.
Ford Motor Company recommends loading the roof rack only when
equipped with (optional) crossbars, to avoid unintended damage to the
roof panel.
Page 143 of my PDF version of the '07 manual. In the Driver Controls section.
-- Chuck
Old 04-14-2010, 05:54 PM
berry1234's Avatar
berry1234
So a body will fit nicely.
Old 04-14-2010, 07:04 PM
gddyup's Avatar
gddyup
gddyup is offline
Thanks Chuck! Seems as if most racks are probably going to be rated in that same rough area. I guess roof thickness and weight limits are pretty much close across the board for most manufacturers.
Good info to know because I plan on picking up a canoe for the family weekend outings this year. Maybe I can carry it on the roof or maybe not.
Old 04-15-2010, 06:02 AM
chuck s's Avatar
chuck s
chuck s is offline
I find having the PDF version of the owners manual very helpful in finding stuff although I had to constantly click Next when searching for "rack" as it stopped every time it found "track." Seems half the manual is devoted to the "entertainment systems."
Implied in Ford's note is that the weight should be on the cross bars, or at least much of it. That's how I read it. We've never used the rack.
Canoe? Just gotta hear your experience that THAT on the roof!
-- Chuck
Old 04-15-2010, 12:53 PM
avesterg's Avatar
avesterg
avesterg is offline
thanks all - I had looked at the pdf of the manual but couldn't find it - was looking in the wrong spot! again, many thanks
Old 04-15-2010, 08:54 PM
gr8dain's Avatar
gr8dain
gr8dain is offline
I have a 20 cu ft old X-Cargo carrier that I have used many times on my 2007. Filled it with luggage and Christmas presents. I have never had a problem.
Dain
mvedepo
All Other Items for Sale
01-31-2018 03:56 AM
rock2610d
05-19-2017 11:03 AM
mdr617
Bronco II
01-21-2014 04:33 PM
paraskr
02-03-2013 02:13 PM
tonyford
Escape & Escape Hybrid
01-04-2006 04:35 PM
Quick Reply: Max Load for factory installed roof rack?
