Electrical issue
On the head unit is that the preset you talking about or the wheel?
Does the other wheel buttons work? If not I would be thinking clock spring
may be bad. If the preset lights are the ones in the head unit it may be as simple
as a failed LED/lamp in the unit it's self.
I don't happen to have the wiring diagram for you year. You may want to check and see
if the head unit is getting power from the illumination circuit. To do that your going to
have to pull the unit out some to get at the wires and check the voltage at the plug
when you turn the dash illumination on and off.
Sean
Sean
rowekmr
04-06-2019 06:00 PM
SUPERDUTY_08
02-13-2012 08:50 AM
S4patrick
02-06-2006 01:13 PM
