any adjustment in the shifter linkage??
I just started having issues on my 2000 V10 Excursion, going into reverse. If I'm in D, I have to go to P then to R. otherwise straight to R will not be recognized. Is there any adjustment to this linnkage? either under the dash or under the hood or at the tranny? any help is greatly appreciated.
Michael
Michael
Your shifter tube may be worn out. There are 2 plastic bushings that ride on the aluminum tube and they do wear out.
I would first check the 2 torx screws on the bottom plate (cable bracket) of your column to see if they are tight. My screws were loose and I had the same symptoms. I believe it was a torx 27. You can locktite them but if you do just use a small speck of blue as you might have to remove it in the future.
Mines doing the same thing ,it got so bad I could hardly change gears, tried all the quick fixes and it didnt hep, so I took it to the dealer,expecting the worse $$ . they said it was a streched cable going to transmission,they replaced for only $120 and now it shifts like new, not a bad price from the dealer -John
papabills54
08-21-2015 12:27 PM
