I think I am looking at too many issues. So to simplify the matter, I need your opinion please.
I am buying a 2001 X with 8,000 miles, a V-10 and a 3.73 rear. In your opinion will it safely tow a TT at 8800 lbs and a tongue weight of 1000 lbs. These numbers are absolute MAX and may be lower.
Like I posted over on RV.net, you will not like towing 9k lbs with the 3.73`s. the truck will work hard doing it. it`s not the weight that is the issue, but the frontal area of the trailer. our trailer weighs in at approx. 9200lbs and is 11.5ft tall. towing with the 3.73`s was a pain. and no you can`t just run in 3rd to make up for the difference, like someone mentioned, because that doesn`t change the gear ratio inside the trans like a ring and pinion swap will! I would definitely budget for some gears. believe me I know. I went from 3.73`s to 4.30`s and the difference was night and day. sure you can tow it, but you wont be happy.
What he said plus plan on single digit fuel mileage with V10 when towing. I don't have 4.30 gear experience with my X but with previous vehicles, it was a huge difference.
They only way you may be happy with 3.73 gears in a V10 is if you primarily pull on flat road. The first 3% to 5% five mile grade you have to pull will burst your happiness bubble.
Also, don't know if you are looking at a 2WD or 4X4. A 4X4 is going to be very expensive to convert from 3.73 to 4.10 or 4.30. FWIW.
What kind of shop does that? Dealerships or elsewhere?
Powertrain or drivetrain shop. The one here is called Jackson Powertrain. Got the gears on my Durango swapped for almost exactly $750 including tax. Went from 3.55:1 to 4.56:1!!! Way fun to drive now. hehe
I think you'd pay WAY more than that at the dealership if they would even do it.
Wow, if you don't mind
What the heck are you paying for an 01 Ex with 8K on it? Sweet find
Haven't completely agreed yet but it will be between $16-17 K
My only concern at this point is the hitches were rated lower in 2001.
I also have a 2004 with 40 K miles for $19 K on the table.
Decisions, decisions....
What are the models, trims & motors of the 04 & 04?
Diesel ? Gas?
