Washer Fluid Leak
Washer fluid leak
Here you go, Fred: https://www.ford-trucks.com/forums/1...t-working.html
I should share that I found the supply side (flex tubing btw) behind the fire wall trim piece. Interesting is that there is not a bridge at the connection. Simply flex OVER THE RIGID. Now think about the fluid dynamics here. Pressure on supply side will press outward. But it is on the outside of the firm hose. Interesting choice.
unleashd
12-21-2017 03:44 PM
