Painting frame
Painting frame
Live where they put a lot of salt down in the winter. Want to paint frame,oil pan, shocks,axles,leaf springs, bottom of the bed, inside up by the fuel cap on the inside, everything underneath is going to get painted. The question is, what to use? Its all painted black now, but its starting to rust a little and want to do it one time and be done with it. I heard people using bedliner, por 15, rust bullet, ect. Whats the best stuff if I only want to do it once?
I used Herculiner bedliner on my rocker panels, and inside of the doors. Really like it, maybe I'll just use that. idk
Gallon - BlackShell Gloss Black, Industrial Grade Protective Coating - Rust Bullet LLC
You have to apply one or 2 coats of that stuff?
If you wanna do it right, go with the POR-15. My brother did the frame on his 78 f150 with it and the stuff was amazing. I chucked a 3/8" ratchet at him one day during a fight, missed him and hit the frame. It didn't even scratch or chip! We still have spots on the concrete floor 8 years later where it dripped. The only downside is it will fade if you leave it in the sunlight, so you gotta top coat it with something.
My plow jeep. Still looks good. BUT, I think with anything and salty conditions you will need touch up.. I plan on doing my jeep again this spring. Once the salt is gone. Hard to tell how well it is holding up because it is all salt stained. The spring i will take a duplicate picture of how well it held up.
Cleaned off any loose stuff with hammer/chisel/brush. etc.
Blew it all off real good with the air hose. Wearing mask of course.
I used a gallon of rustoleum. No thinner. Sprayed it on with the Wagner Piston pump.
Last summer
Here is a pic I took of the front air shock install mod. No rusties on the frame yet but lots of salt. Mid January pic.
Last summer
ha! my first post! - been lurking for months. I've been thinking about doing this on my SD and wonder if anyone has used Magnet Paint's Chassis Saver? I've heard it's good and it looks like it's priced a hair under POR-15. I'm curious if anyone has had any first-hand experience to compare the two?
ive always stood behind POR15 but if theres something better im all for it
