Can't downshift to 2nd
I was coming down a long, steep grade yesterday and noticed that I couldn't downshift to 2nd! Last month the brakes needed replacing and before I got around to it I was gearing down alot to take some pressure off the brakes but now it won't go into 2nd - like the shifter is stuck.
Any ideas?
Any ideas?
I had a similar problem. I found a small pebble was obstructing the gear selector on the transmission housing. The pebble had been there for some time. The connector that is behind the steering wheel inside the cab is held on with two screws. These screws were so loose, one was totally disconnected and the other was partially disconnected. I tightened them both up and the gear selector behaved normally. I would double check under the vehicle, specifically around the transmission housing where the gear selection lever lives. Then I would go under the dash where the connector hides.
Good luck! Al Burgess
