Step one in converting yj to ford undercarage
So il start off with the store....simple I wanted a early bronco and my old man wanted a jeep...so I ended up with a 1995 jeep yj, So after lots of swearing and bitching after the weak dana30 and dana35 axles I decided that I was gona do a axle swap. While my old man is overseas.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
-My first option was a set of early bronco axle with the arms and somehow retro fit the bronco dana44 front suspension setup with the arms to the jeep with the rear being the 9inch.(I gus this would be wicked setup if it work) <o></o>
<o></o>
-My second option is a set of 1968 f250 axles with closed knuckles with a matching rearend. <o></o>
<o></o>
So what’s the best? Should I use the early bronco axles or the f250 closed knuckles? Or try to find another setup….
i intend on running 38inch tires that have 15 inch rims so am looking for a setup that is able to use 15ich rims so i dont have to get rid of my tires.
let me know what you think
<o></o>
<o></o>
jcardwell3rd
23
07-06-2011 06:57 PM
keithredfirebird
04-30-2010 07:28 AM
ThaFrenchy
03-03-2010 04:18 AM
kittyhawksurf
1999 to 2016 Super Duty
33
07-10-2009 03:58 PM
