transmission troubles Help !
Old Feb 27, 2010 | 04:08 PM
rainman31's Avatar
rainman31
I have a 2002 expy EB 2wd . it has 131,000 miles . a week ago the OD light started flashing , OD wasnt working nor was first . had a friend of mine drive it with his scanner running and it was showing the related solenoids not working . he said replace solenoid pack. i did with a refurbed one . maxivaced the whole system, repalced filter . all new fluid . now it wont shift from 1st - 2nd unless you let off gas a lil. the OD light isn't flashing but the service engine light is on showing code p1715 . please can someone help me !
Old Feb 28, 2010 | 01:15 PM
pdqford's Avatar
pdqford
I can't find a P1715 in my manuals for a 2002 Expy.
Maybe if we knew which engine / tranny you had, it might help someone to respond.
Old Feb 28, 2010 | 02:12 PM
alloro's Avatar
alloro
Code P1714 is "Shift Solenoid A Malfunction."
Did you disconnect the battery for 10 minutes after the solenoid pack was replaced?
Old Feb 28, 2010 | 11:11 PM
rainman31's Avatar
rainman31
hey guys thanks for the response , my expy has the 5.4 L , and the tranny is 4r100 . i did disconnect the battery . I stopped by autozone to get them to hook there scanner . it showed code p1715 also , but there computer gave 2 possibles , low or dirty fluid or shift solenoid b malfunction . would that solenoid be in the pack i replaced or are there others in the trans that are showing up now that the pack is good .
Remmons
Oct 12, 2015 09:11 AM
02f550
May 15, 2014 08:47 PM
75Three90
1997 - 2003 F150
Mar 23, 2013 09:43 PM
f150xlt96
Apr 5, 2003 10:30 AM
