Belt size needed
</nobr> 4x4 with a straight six and need help on what size belt I need when removing the a/c and air pump. I had to do a h/g, and found that my ex mani's were both about to fall in half, so I put a header on it. Now, I don't want to put the air pump back on, since it wasn't connected anyway. It is still apart, so I can't measure myself, and thought surely someone else has done it and can help. It does have power steering.
Welcome to FTE, hope you enjoy a long and helpful stay. There R a lot of helpful folks 'on' here. They have taught me/saved me hundreds of dollars both of which is why I'm here.
U put, I believe it's called, a link on your post. Many do this when showing a pic of something they R asking help with. I attempted to open that w/o success.
Further, U posted very recently - in a fairly open forum, w/o much specific info on application. Someone more helpful will be along shortly. In the mean time how bout a belt or string run along/around the accessories U WILL be using that is then taped off for length? Many take that to the shed for comparing to spares or to the parts suppliers for a closer match.
Good luck!
89 f150 4x4 shortbed
str 6
deleting a/c and air pump after header install
pulleys, alt and belt are not on it yet, thus the search for anyone else that already knows before I put it all back together.
That's everything I posted in the first post. ?? I know my way around cars/trucks, and can't see anything else relevant that I should share??
