6.0 trans cooler?
Tru-Cool 4739
Bob Riley sells the unit for 120.00, best Ive seen and I installed mine with no problems.
Its the one they install in the V10 rigs,
The stock 7.3L cooler is a 28k GVW model. This Tru-Cool Max 4739 unit is a 40K model.
Picture Installed
Picture Installed
Tru-Cool 4739
Picture Installed
Picture Installed
Corwin- any truck 03-07 with the 6.0 diesel will have the big cooler. Not sure if the Ex is the same but I'd guess it is. There are 2 flavors, 27 row and 31 row. Either are more than sufficient for a trans cooler. The thing is about the size of a Honda Civic radiator
The 6.0 coolers sometime pop up on Fleabay from time to time also. Funny, the prices usually are higher come the summer months so now is a good time to start snooping around for them. Also, in 2003 model year, there are some SD's with came with the 7.3's (switchover to the 6.0's happen in mid model year) which means they will have the smaller cooler.
There are 2 versions of the 6.0 tranny cooler: the 26 row (5C3Z-7A095-CA) and the 31 row (5C3Z-7A095-CB). The 31 row was the early one. I'm not sure but I think around 2005 they switched to the 26 row. The 26 row is a redesigned cooler that is more efficient (almost as efficient as the 31 row) and cheaper than the 31 row in case you were interested.
I'll try and find the pic, hang on a few. Basically the Tru-Cool and the stocker together are almost the same size as the 6.0 cooler.
I think you are mistaken. The tru cool is NOT that big. The 6.0 cooler is the size of the radiator not the tru cool. How is the 6.0 better? It fits securely without zip ties and other fan-dangling.
