ATS TURBO UPGRADE KIT'S IN STOCK..BETTER HURRY - Page 4 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
  #46
Old 02-16-2011, 09:50 PM
wreckinball's Avatar
wreckinball
wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
so with the 2" body lift, is there anything else needed? like brake lines, anything? If its just the lift, then i am game!!
  #47
Old 02-16-2011, 09:57 PM
Coalroller's Avatar
Coalroller
Coalroller is offline
Coalroller is starting off with a positive reputation.
i have the stock outlet housing and smashed down pipe (for now till i get around to puttin the banks down pipe on ) and it whistles like a moded turbo.
  #48
Old 02-16-2011, 10:29 PM
wreckinball
now thats what i want to hear hehehe!!
  #49
Old 02-17-2011, 10:08 PM
Coalroller's Avatar
Coalroller
Granted i also have two 7" stacks right behind my head lol that really let the whistle out of them till i put my foot in it. Then she gets that nice deep growl
  #50
Old 02-17-2011, 11:18 PM
my85fordIDI's Avatar
my85fordIDI
my85fordIDI is offline
my85fordIDI is starting off with a positive reputation.
wrenckinball ya I just installed my turbo and I put the 2" body lift and theres plenty of room
  #51
Old 02-18-2011, 12:03 AM
wreckinball
so what all is in the body lift and what is a good source. Also what is the method to lift the bed? same kit or no?
  #52
Old 02-18-2011, 08:13 PM
Coalroller's Avatar
Coalroller
you just buy the kit for a 250 gasser and put that on... i believe there is some trimming of the maybe fan shroud or something in that area and a few other small mods. I would message oreo or 85 in the post above ya and see what they say
  #53
Old 02-18-2011, 08:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
When I installed mine that I got from a local off road shop, it came with enough hardware for the cab and bed.
When you do the cab, loosen all of the cab bolts, 6 of them.
Only remove one side at a time, that keeps the cab from getting far out of alignment.
After that side has bolts and nuts back on, remove the other side and install it.
Now tighten down all of the bolts.
I had to modify my transfer case linkage, it hit the cab before it went in 2 wheel high.
I also modified my park brake cable mount, just because I was not comfortable with how tight is was stretched.
You also want to check out your steering shaft to make sure it is not about disconnected, mine was fine.
The electrical wiring had plenty of room.
The brake lines also had plenty of extra tubing, but as you raise the cab watch they don't kink.
Also the fan will hit the fan shroud, so it either has to be relocated or the bottom cut for clearance.
I relocated mine so the fan was back in the center of the hole.
Since I have a dump bed, I did not use the bed part of my lift kit.
You would most likely have to extend the fuel tank filling tubes when you installed the bed lift.
Also be aware, the radiator support bushings in my truck were in bad shape.
When I tried to pull the bolts out of them, they disinegrated.
So I had to get an upper and lower bushing for both sides.
The front and rear bushings were fine.
If you have an auto tranny, you will also have ot work on that linkage a little.
  #54
Old 02-19-2011, 12:05 AM
wreckinball
awesome dave thanks, body lift it is!! hahahaha
  #55
Old 11-16-2011, 01:40 AM
George D.'s Avatar
George D.
George D. is offline
George D. is starting off with a positive reputation.
Hold on am I reading this right ATS has the upgrade kits now?
  #56
Old 11-16-2011, 06:42 AM
mistakenID
mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
The original post was in 2010, last post was Feb 2011. Everyone that has contacted ATS for the upgrade has been disappointed. I believe I read that a few had gotten the larger housing/downpipe sometime last year but ATS quickly ran out.
91f350idiats
06-24-2016 06:14 PM
Mark_in_co
05-06-2016 03:44 PM
MtTheJeffro
11-28-2015 03:18 PM
ifrythings
50
11-29-2012 09:16 PM
1973dieselhighboy
02-22-2011 10:33 PM
Quick Reply: ATS TURBO UPGRADE KIT'S IN STOCK..BETTER HURRY
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
