12 to 6 voltage question
First it's a good idea to replace the horn relay, if you plan on using the horn a lot. Otherwise, it will just draw a little more current in the relay than needed.
If you take the back "dome" off the horn, you'll see a set screw and locking nut. (I'm going by memory) adjusting the screw changes the tone of the horn. With 12v it probably sounds toohigh-pitched. Play with it until it wounds the way you like.
