chamber is off?
chamber is off?
Hey everyone, my truck has a 3" body lift.
Recently I had procomp leveling springs installed with rancho shocks so that I can fit my new 35" on
When they did this they had to put a chamber kit in because of the levelling kit.
The problem is now that my tires look tilted in at the bottom (they look a bit pigeon toed if that makes sense).
I took it back to the shop that did the alignment and they tell me that this is a common problem with f150 my year when you do this kind of lift. He said with the Independent front suspension they have adjusted it as far as it will go and all I can do is rotate my tires every year.
Does this sound normal or does it sound like these guys are being stupid.
Thanks!
I have a
1994 f150 4x4 300
Thanks!
I have a
1994 f150 4x4 300
The guys at that shop are morons who don't understand how to lift a truck.
You just had leveling springs installed? 1.5" or 2", right? Then the shop that did installed the kit should know that they have to install aftermarket camber bushings to correct for the lift. They are definitely available, other users here have used them. Anything more than 2" of lift in the front will require drop brackets though.
I don't know what it would cost for drop brackets. If it were me, I would take it back, tell the shop that I am unsatisfied with the quality of their work and lack of expertise and either return my truck to stock or correct the camber even if it means installing a slightly smaller kit.
You SHOULD NOT accept poor tire wear and incorrect alignment as a consequence of a leveling kit. A proper kit will align just fine.
