1998 Rear Wiper Problem
Old Jan 19, 2003 | 08:44 PM
MajinInsane's Avatar
MajinInsane
1998 Explorer. Had the rear wiper assembly replaced under warranty when it would only work intermittently. Since then, under warranty, I had to have the assembly tightened. The wiper would miss the glass and it would park on the rest but would still slightly over the glass making it difficult to open and close the glass. After it was tightened it was fine for a while. Now it has loosened or moved again. The nut under the cover on the arm is not loose. Is there something in the rear hatch that needs to be tightened or adjusted? If so, how do you remove the trim panels from the interior of the hatch to get to it.?
