wiring pinout for 99-00 and 01-07 headlight switch
Old 02-14-2010, 05:51 PM
jeffdoerr's Avatar
jeffdoerr
jeffdoerr is offline
I want to upgrade my dash bezel to the 05 style, but my headlight switch has the older style plug. I was just looking to see if somebody has the pinout of both switches, the 99-00 old style and the 01-07 style. No auto lights, just plain on/off with running lights and pull out for foglights.
thansk
Old 02-14-2010, 06:38 PM
twags6's Avatar
twags6
twags6 is offline
This is the pinout on the plugs for the 01 pickup headlight switch. Is it what you're looking for?
File Type: pdf
Old 02-15-2010, 07:12 PM
jt371's Avatar
jt371
jt371 is offline
______
jeffdoerr, any pics, how much of the dash did you swap, how hard to do?
Old 02-15-2010, 07:21 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
I may be able to get the 05 diagram for you when I get home in a couple of days
Old 02-15-2010, 07:29 PM
jeffdoerr's Avatar
jeffdoerr
i was able to get the rest of the pin outs today at the dealer. Now I gotta get a harness pigtail and I should be ready to rock and roll on this. I will post pics after I get done (if all works well, by thursday)
Old 02-16-2010, 07:36 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
subscribed.....sounds interesting
Old 02-23-2010, 10:56 PM
goodybrain2001's Avatar
goodybrain2001
goodybrain2001 is offline
looking for headlight switch diagram for a 2002 E350 Ford econoline 7.3L Deisel my high and low beam and curtacy lights work but my daytime running lights are inop.Fuse ok and tryed a known good daytime modual
Old 02-24-2010, 06:41 AM
bobmiers's Avatar
bobmiers
bobmiers is offline
There is a voltage dropping resistor in the DRL circuit - usually found below the driver's side headlight. Check that it isn't open.
Old 01-02-2017, 03:46 PM
brodix's Avatar
brodix
brodix is offline
diagrams
Old 02-24-2018, 01:45 PM
bakerbuilttracks's Avatar
bakerbuilttracks
bakerbuilttracks is offline
subscribing
Old 07-06-2022, 05:20 PM
MS. Understood's Avatar
MS. Understood
MS. Understood is offline
2nd Gear
Multi function switch help please
I'm in desperate need of the pin outs for the multifunction switch plug for a 2003 Ford f250 6.0 diesel I believe the plug numbers are Wpt-506 and wpt-516. Thank you in advance
KansasJoe
1999 to 2016 Super Duty
29
08-14-2022 08:15 PM
b-grant
2017+ Super Duty
09-01-2017 05:45 PM
BBslider001
16
03-22-2017 08:58 PM
Jjona5
17
01-16-2017 09:20 PM
6.0 and 7.3 United
06-27-2016 02:51 PM
Quick Reply: wiring pinout for 99-00 and 01-07 headlight switch
