wiring pinout for 99-00 and 01-07 headlight switch
I want to upgrade my dash bezel to the 05 style, but my headlight switch has the older style plug. I was just looking to see if somebody has the pinout of both switches, the 99-00 old style and the 01-07 style. No auto lights, just plain on/off with running lights and pull out for foglights.
i was able to get the rest of the pin outs today at the dealer. Now I gotta get a harness pigtail and I should be ready to rock and roll on this. I will post pics after I get done (if all works well, by thursday)
looking for headlight switch diagram for a 2002 E350 Ford econoline 7.3L Deisel my high and low beam and curtacy lights work but my daytime running lights are inop.Fuse ok and tryed a known good daytime modual
There is a voltage dropping resistor in the DRL circuit - usually found below the driver's side headlight. Check that it isn't open.
I'm in desperate need of the pin outs for the multifunction switch plug for a 2003 Ford f250 6.0 diesel I believe the plug numbers are Wpt-506 and wpt-516. Thank you in advance
