'07 EB Rattling Front Passenger Seat
Just checking with others to see if they have had any issues with their manual front passenger seat rattling. In my '07 it has become extremely noticeable over the past couple of months. The last time I took it in to the dealer they said it was "normal."
I'm pretty sure I have narrowed it down to the front and rear seat bottom adjust lever/bar being loose. I can duplicate the noise just by banging on the seat but if I push down on that bar and bang the seat I get no noise.
Anyone else have or had this "NORMAL" noise?
Needless to say I'll be going to a different dealer for the next visit before the 36k/36mo warranty runs out soon.
My old '09 Limited did that too. You can see how much the headrest moves laterally when driving as well as punching the seat on its side. No rattle when someone sits on it, though. It was a power passenger seat, though.
I felt a "rocking" sensation on my driver's seat front to back when driving as well. My guess is that the power seats are still not solid. My old '98 EB Explorer did that pretty badly, had it fixed by a TSB under warranty, but it still rocks some. But as long I have the power seats not raised up, it was fine.
It doesn't hurt to ask the other dealer about this.
I tried the power seats in other brands and they were solid as they should be...
These types of problems are best fixed on your own.
Have someone or yourself bang on the chair as you look under the seat with a flashlight. Locate the source of the rattle. It could be the spring attached to the bar that is lifted to adjust the seat. Once you find the two metal/plastic surfaces that are causing the noise, put tape, felt, anything you can use to insulate the materials so they don't rattle.
Mine has the exact same rattling you're describing, except that I have to pull up the bar to unlatch for the rattle to stop. Didn't take it in because I have the worst luck getting noises addressed at several dealers around here, and it may be a waste of my time to bring it in. Would be good to know if yours gets fixed.
Took my Expy to another dealership a couple of weeks ago, two days before the 36 month warranty ran out. They confirmed the seat rattle issue and ordered a new seat track under warranty. I took it back in about a week later and now all is well.
Also during the oil change being done during the first visit the battery tested weak. They replaced it for free under warranty
rver
1999 to 2016 Super Duty
11-15-2002 07:43 PM
