Hub Nut Waaay loose-
Hi all,
I recently pulled my front auto hub to check it, had vacuum problems. The vacuum problem is figured out, but I did find another problem I think. When I pulled the hub lock, the nut inside was loose. Loose enough it is not engaging any threads. The clip is still there, and my 4WD seems to be OK, albeit with getting out and manually locking them up.
The wheel is being driven, and I get some more vibration and noise. Other than that, nothing real eventful has happened, but yet would be the key term here.
Any thoughts as what to look for before I rip into it?
Thanks,
Digger
Thanks,
Digger
Well, I will start out with Whew! Not a lot of play at all. I will keep going with I feel like a complete moron.
I am getting more vibration now from that hub when I either gas it, or the exhaust brake kicks in. If I just hold the truck at a steady speed, it isnt nearly as loud.
I am likely going to replace the hub bearing and ball joints when I get into it. I need to replace the yellow O ring anyway, and with 243K, it needs ball joints. Any idea what the vibration might be. Seems to very high "pitched", like a high frequency in my foot when it is on the pedal or floorboard.
Thanks Guzzle!
Thanks Guzzle!
It sure sounds as if you have an impending main hub failure. With the wheel jacked up, can you feel movement when you try moving the tire side to side and top/bottom in and out? If so, you may want to look closer to see if it is ball joint slop or bearing slop.
Block the truck and use good jack stands!
kissfan79
11-18-2013 09:41 AM
Otahyoni
31
09-28-2010 12:10 PM
