97 F-350 Dump: Wiper Problem...It clicks, but doesn't work...
Old 10-15-2012, 05:41 PM
ArlyDude's Avatar
ArlyDude
ArlyDude is offline
When I activate the wiper switch, I hear a clicking noise, coming from where the wiper motor is... I am assuming, sounds like the passenger side of the truck by the glove compartment, and it just clicks and the wipers do not move. I am assuming I need to replace the wiper motor. Let me know your thoughts, thanks!
Old 10-15-2012, 10:17 PM
stewart89's Avatar
stewart89
stewart89 is offline
Sounds like a relay switch if your hearing the click. Don't quote me on that though.
Old 12-14-2014, 09:32 PM
Kcorrie's Avatar
Kcorrie
Kcorrie is offline
Sorry to dig up an old post but I have the exact same problem and thought it better to get an answer here than start a new post. Everything else that has come up in searches is typically for older trucks with switch or control module problems.
Echoing the OP... My wipers don't work. They haven't worked since I bought the truck. I don't drive it much and am just getting around to working on the problem.
The fuse is good and I have power at the fuse box. When I turn the wiper switch I hear the control module behind the glove box click so I assume the switch and control module are good. I thought the motor was bad so I replaced it but the wipers still don't work.
At this point I assume the problem lies between the control module and motor but I'm not sure how to test further. I would test for power at the motor but I'm not sure what the pin-out for the connector is. Your help is appreciated.
Grizzly4x4
10-21-2014 02:57 PM
Fox
11-20-2007 06:19 AM
truckeetom
08-18-2005 12:22 AM
kcdan
1978 - 1996 Big Bronco
10-27-2003 01:04 PM
Rmcmorris
1997 - 2003 F150
08-03-2003 08:49 PM
Quick Reply: 97 F-350 Dump: Wiper Problem...It clicks, but doesn't work...
