87 Bronco w/AOD & no fwd/reverse
I recently purchased an 87 Bronco w/302 & AOD tranny. Supposedly the guy had the tranny replaced & claims he drove it around the block but had to park it due to antifreeze leaking. I've replaced the radiator & it runs but has no motion in any forward or reverse gears. I checked the tranny fluid level (with motor running) & it appears to be 1 to 1.5 quarts overfull and quite clean. I pulled the trans cooling lines to the radiator & no fluid comes out with the truck idling. Is it possible the front pump in the tranny is bad, or that the torque converter wasn't bolted up & actually freewheeling?
I've searched the board & found a couple leads, but looking for a bit of input
thanks in advance for any input!
SnEaKyMudDigger
05-18-2014 10:08 PM
1wvboy
03-04-2012 02:10 PM
pud
12-29-2008 02:21 AM
