doing the 9", need lower f2 shock mount
Old 02-11-2010, 09:46 AM
r_reed's Avatar
r_reed
r_reed is offline
r_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to behold
we will be putting a 9" in my '49 f-1 this spring. thought i would test the waters to see if anyone has a pair of lower f-2 shock mounts for sale to save us doing a ham and egg fab job. if you have some, let me know. willing to pay fair price (plus shipping obviously). thanks, dick r
Old 02-11-2010, 10:57 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Check Speedway Motors - Racing Equipment, they have plates that look like just what we need for the 9" swap - haven't had time to completely check it out.
Old 02-11-2010, 11:09 AM
Old F1's Avatar
Old F1
Old F1 is offline
Old F1 has a very good reputation on FTE.Old F1 has a very good reputation on FTE.Old F1 has a very good reputation on FTE.Old F1 has a very good reputation on FTE.
For the unwashed and unworthy (myself), does anyone have a picture of the elusive endangered species F 2 lower rear shock mount, I have never seen one and would like to before they become completely extinct. Thanks.
Old 02-11-2010, 11:27 AM
Old F1's Avatar
Old F1
Old F1 is offline
This the one Dick?
Speedway Motors - Product Summary
Old 02-11-2010, 11:52 AM
r_reed's Avatar
r_reed
r_reed is offline
dick c. sure looks like what i need. i'll call speedway and make sure it's what we want and report back. i haven't even picked up the 9" yet (prob tomorrow or poss next week) and my truck is parked outside covered in snow. i knew i could save some time calling on the collective brainpower of fte. dick r.
Old 02-11-2010, 12:15 PM
r_reed's Avatar
r_reed
r_reed is offline
talked to the speedway tech for a couple minutes. told him (i think i'm right here) that the f1 springs are 2" wide. he said we might had to mod the plate for that (most springs are 2 1/2"?). once it is bolted in, would that be an issue? do we need to weld in some spacers to keep the axle from sliding sideways? from pics the speedway looks very similar to stock but will accommodate a 3" axle. dick r.
Old 02-11-2010, 12:34 PM
HD74's Avatar
HD74
HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
The problem I see with the spring plate posted above is that you will have to relocate your upper shock mounts. Keep in mind that your springs are outside of the frame.
A picture of a pair of F-2 spring plates.
Old 02-11-2010, 01:33 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
bobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant future
The F-2 brackets look the same as the F-1, just a little larger.
F-1 on left, F-2 on right:
Old 02-11-2010, 01:41 PM
jaye's Avatar
jaye
jaye is offline
jaye is starting off with a positive reputation.
The springs shouldn't slide from side-to-side due to the bolt head being engaged in the center hole that, along with the pressure of the U-bolts sliding shouldn't be an issue.
Old 02-11-2010, 01:50 PM
Old F1's Avatar
Old F1
Old F1 is offline
Thank you Bob and HD for the pics!
(Iím humbled in the presence of such greatness.)
Old 02-11-2010, 02:25 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
There are a couple of other one also - spaced closed to the F1/9" with weld on locators.
Old 02-11-2010, 08:09 PM
TxF100's Avatar
TxF100
TxF100 is offline
TxF100 is gaining momentum as a positive member of FTE.
I would look at the 58-60's F100s. That is what I got ,and they will fit allow the 9" to use the stock upper shock supports. There are 3 pcs. for each plus the U-Bolts. (a top plate, the bottom cast piece and the shock support.
Sorry about the picture, it was all I have on this computer.
Old 02-11-2010, 08:12 PM
firstrider's Avatar
firstrider
firstrider is offline
firstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to behold
No Limit has a relocating kit .Worked perfect for me !!
Old 02-11-2010, 10:45 PM
Old F1's Avatar
Old F1
Old F1 is offline
This it? Rear End Components-No Limit Engineering
"AXLE BELOW THE LEAF" For those of you who want to slam your truck in the weeds, this flipped axle kit is the ticket, a 6" drop. Complete with: Axle pads, u-bolt plates, shock mounts, and hardware.
Old 02-11-2010, 11:53 PM
HD74's Avatar
HD74
HD74 is offline
I just did that with components from Chassis Engineering but only got a 3 inch and change drop.
[/IMG]
Quick Reply: doing the 9", need lower f2 shock mount
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
