Transmission won't upshift - OD light flashing
I have an '01 Ford F-150 4x4 crew cab with the 5.4 V8 AT w/OD. Transmission will not upshift. Seems to be "stuck" in second gear. Will shift into N, R, and P ok. OD "on" light on shift column is flashing. OD will not shift, flashing light stays on.
I am getting OBD "P" codes 0743, 0750, 0755, and 1747
Help,
Larry in Idaho
Help,
Larry in Idaho
Help,
Larry in Idaho
Help,
Larry in Idaho
If you are able you can install it yourself and still have the warrantee.
A $15 "FIX"
OK....I spent $15 on one of the Ford Mechanics at justanswer.com/car/ford. He wasn't much help until I was able to give hime the OBD codes. He then directed me to the 15 amp Fuse # 23 in the fuse box under the hood. Sure enough, it was blown. I replaced it and....VOILA! Trucks works & shifts like it did a week ago.
So...my next question (which the ASK Mechanic did not answer...probably wants another $15) is where should I start looking for the short/problem that caused Fuse #23 to blow? Any help???
A lot better than replacing the Tranny!
Thanks,
Larry in Idaho
Thanks,
Larry in Idaho
Thanks,
Larry in Idaho
Thanks,
Larry in Idaho
Glad you got it going.
I looked through my service manual and must be doing something wrong as I can find the fuse panel or wiring diagram for the trans.
What does your owner's manual say fuse #23 is for? What else became operational when you put the fuse in? Just a guess; that fuse may power the solenoid pack in the transmission. Until you have it cured for sure you should carry a bunch of those fuses in your glove box as insurance.
The $15 answer man sent me a diagram of the engine compartment fuse box with #23 highlighted and said to check it as it did indeed run the Trans Solenoids. I had no spare fuses so I pulled the "Audio" fuse from my interior fuse panel to get it running. I have only driven the truck a couple of miles around the neighborhood...but tomorrow I go to town (20 miles) and stock up on 15 amp fuses! The $15 Mech. said to check the wiring from the fuse panel to the Trans. to look for a possible short. Any other suggestions???
Thanks, Larry in Idaho
3000gtman
45
10-21-2016 08:57 AM
mototrig
18
03-22-2016 08:22 AM
sethticlees
Escape & Escape Hybrid
10-01-2010 03:50 AM
sunrack
08-24-2010 06:37 AM
F150Guy87
05-08-2006 05:03 PM
