Tailgate Question I Bet You Haven't Seen Before?
On my 2008 with the step in the gate I put on a raider top and they had to make a special molded plastic piece for the bottom of the cap door to fit over the plastic cap on the gate. Call whoever makes your top and see if there is a piece available it should not cost that much.
Scraprat,
Are you saying the '99 molding will fit all of the holes in the '08 tailgate AND match the contour of the '08 sheet metal? I was thinking that wasn't the case. You have a PM with my phone number if it's easier to speak with me directly.
Thanks
Scraprat,
Thanks[/QUOTE]
No, this is the stock '08' moulding piece. I was going to take a picture of it but wanted the truck tailgate back as it should be.
The pre '08' gates are rounded and not flat at the top.
Thanks[/QUOTE]
The pre '08' gates are rounded and not flat at the top.[/quote]
Agreed. However, the top of the molding is not the issue for me, with the exception that on the '08 the sheet metal underneath won't allow for a pre-'08 molding. My issue was the molding aspect on the face of the tailgate. It is this aspect of the molding that the topper hatch closes against, overlapping the molding. Despite an '08 tailgate fitting a '99 truck, due to the difference in molding lines and being unable to put a '99 molding on an '08 tailgate, I'm stuck with a tailgate that is useless to me
None the less, thanks for the help in getting me to come to this realization
darmento
03-28-2016 04:13 PM
mhollas8908
1999 to 2016 Super Duty
01-20-2013 07:16 AM
