Manual locking hubs???
Old Feb 7, 2010 | 07:03 AM
magnet1's Avatar
magnet1
I have read a lot of the IWE threads lately because of some issues with my 4wd. I have not had my Ford long; And this may be a really dumb question but....Does any body make a manual locking hub conversion kit for these year trucks to bypass the vacuum system and all their issues?
Old Feb 7, 2010 | 10:06 AM
screwy's Avatar
screwy
No, and it's unlikely there will ever be with the way it's built.
Old Feb 7, 2010 | 06:40 PM
magnet1's Avatar
magnet1
It would be nice if there was a way to "cap off" the vacuum system and have a manual kit to convert to. Oh well...I can dream.
Old Feb 7, 2010 | 06:50 PM
jester8484's Avatar
jester8484
agreed
in the off road world manual hubs are far superior to autos.
autos tend to grenade, and the front axles catch way more wear with autos then manual.
i'd support the conversion on my 2005 aswell, but in teh mean time ill be sure to run it in 4x4 at least once a moth to keep things moving
Old Feb 7, 2010 | 06:51 PM
maxtruck00's Avatar
maxtruck00
vacuum system?? there are no hubs at all.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Feb 7, 2010 | 07:08 PM
jester8484's Avatar
jester8484
<INPUT id=gwProxy type=hidden><!--Session data--><INPUT id=jsProxy onclick=jsCall(); type=hidden>
you know i really don't know.. i havn't explored my 2005 F150 yet.
I assume it had auto hubs of a classic design... but im not sure whats it has
anyone?
Old Feb 7, 2010 | 08:14 PM
Ryan50hrl's Avatar
Ryan50hrl
It has the equivalent of a vacuum hub.....its called an IWE......same thing really.....and for the ones you hear about that break....theres a few hundred that run problem free...
Old Feb 7, 2010 | 09:38 PM
maxtruck00's Avatar
maxtruck00
ummm no, no hubs at all. just a shift motor in the transfer case. crawl under the truck with the truck in 2wd the front shaft does not spin free, front shaft spins all the time. hubs on f150 went out with the 2003 model i believe.
Old Feb 7, 2010 | 10:43 PM
kameronth's Avatar
kameronth
It is a vacuum hub set up. The axles should not turn in 2wd unless the truck is off due to lack of vacuum.
Old Feb 7, 2010 | 10:55 PM
Ryan50hrl's Avatar
Ryan50hrl
Nope....not quite right.....
When you are in 2wd....there is vacuum running through the solinoid behind your battery....however when you shift to 4 wheel drive...it removes that vacuum allowing the spring loaded hubs (or the integrated wheel ends) to reingage and lock you into 4 wd.
In 2003 and prior the hubs defaulted to unlocked, however 2004 and later they default to locked if you lose vac.
Go look it up.... IWE
Old Feb 8, 2010 | 09:46 PM
SpacePirate's Avatar
SpacePirate
In my reading (I've got this issue myself), I'd heard of people uncoupling the vacuum on the IWE, causing the hubs to remain locked in. From this point, is there any way to manually lock the thing into 4WD? I've seen people mentioning that this can be done, but they never went into great detail. Storm's acoming, and having a truck with mere 2WD is kinda pathetic.
(In my case, I'm pretty sure the transfer motor is on the fluke, or otherwise shot).
jleo
Jan 1, 2023 10:24 PM
83Clevor
15
Sep 12, 2020 06:39 PM
SSBMX
Jun 24, 2016 02:58 PM
cattlerancher
Nov 27, 2014 08:43 PM
Tox
Nov 5, 2007 09:05 PM
