Parking brake cables again F350
I appreciate all the respoinses the last time i brought up this topic. I went with Rock Auto's cables because they listed the lengths beside the picture of the cable. They came in yesterday - wrong length. They are not as long as they need to be nor as listed on the picture. I called them and they said they would contact the supplier.
Both Rock auto and NAPA list the same part number for this application as do other parts houses. They are all wrong. The sheath is too short.
Why am I writing?
73 to 75 are the only cables listed to fit my application. Might any one know what changed in 76? Did the cables switch to running along only one side of the frame instead of the middle maybe? Maybe the change was so slight that icould be looking for a newer year.
Monday I will get ahold of green sales and try and get origanal cables from ysk or maybe that obsolute parts place. Aftermarket has delayed my project by 1 month, as well as tied up my lift and made me use a fork lift to move my 74 around.
Why am I writing?
The part number you gave me is C9TZ 2A635
The local ford garage gave me dif numbers for each side. The ones I took off were the same in length.
BC95786 is the aftermarket number that is used by lots of suppliers.
The sheath on these after market ones are only 39 inches. The sheath needs to be at least 41 1/2. 43 would be best.
I tyried parts vioice but I cannot get on any more. Obsolete parts does not have it. They say there is after market and on order. Green sales is closed today.
Sam
Sam
I, too, have a '76, but an F150 Supercab Trailer Special. My cables were seized when purchased (not unnusual!)and I needed new ones. I spent hours combing the junkyard to find the right lengths of both cable and sheathing. But, I did succeed. I bought one side from a parts store, but the other side was wrong. That is why I hit the junk pile. I found a cable that looked like new and was the right length, so I bought it for next to nothing. No idea why there were so many different lengths of cables for the same truck! Different configurations as well...
From the actual Ford parts catalogue:
1973/75 FORD F350
136" Wheel Base Regular Cab .....(parts section 23.2 list 17B)
2 - C9TZ-2A635-A Rear brake cables - right/left are the same
1- D3TZ-2853-C Front brake cable (BEFORE serial # T40,001)
OR----------------------------------
1-D4TZ-2853-B Front brake cable (AFTER serial # T40,001)
__________________________________________________ ____________
140" Wheel Base Regular Cab ......(parts section 23.2 list 17C)
2-C9TZ-2A635-A Rear brake cable right/left are the same
1-D3TZ-2853-A Front brake cable (BEFORE Serial # T40,001)
OR
1-D4TZ-2853-F Front brake cable (AFTER Serial # T40,001)
__________________________________________________ _______________
Correct information gets correct parts numbers....from this dummy...from anyone else...quien sabe!
1973/75 FORD F350
OR
136" or 133"
from auto parts giant.
WAGNER F108585 PARKING BRAKE CABLE
Note: rear left; w/155"wb 24.54
WAGNER F113230 PARKING BRAKE CABLE
Note: front; w/155"wb 49.73
WAGNER F108575 PARKING BRAKE CABLE
Note: front; 155"wb; 4 wheel drive 26.91
WAGNER F108580 PARKING BRAKE CABLE
Note: left rear; awd; w/133"wb 22.88
WAGNER F38603 PARKING BRAKE CABLE
Note: services cables up to 120"; fits most models 21.58
WAGNER F108584 PARKING BRAKE CABLE
Note: rear right; w/155"wb 24.54
WAGNER F108579 PARKING BRAKE CABLE
Note: right rear; awd; w/133"wb 22.88
WAGNER F126813 PARKING BRAKE CABLE
Note: w/136"wb; incl left/right rear 17.44
DORMAN - STOP FIRST C126813 PARKING BRAKE CABLE
Note: rear left & right; 136" wb 17.47
Dennis, I don't give a scheiss what Wagner says. The Ford Parts Book says otherwise.
This guy has been going through hell trying to get the correct brake cables.
The information I gave him is correct . And is verifiable by going to the Parking Brake Application Charts Section 23.2 in the 1973/79 Light Truck Parts Catalog.
Mine is a 137" wheel base, f350. It turns out there is a guy about 1 hour away from here that makes cables. I am going to call him tomorrow.
I believe all of you and want to thank you for your support.
For what ever reason, there are specs out there that manufacturers are going by that are wrong. The fact that these cables only fit three years might be a reason they might not be available by very many auppliers. I will let you guys know how I make out.
For what is is worth. I carried out the running gear completely done execpt for the rear cables,drums, wheels. I carried in the engine.
So, what do you have, a Regular or a Super Cab?
Here's a pic of the parking brake application charts for F350's.
If you still have your old cables, there is company that will make new ones using your old ones as a pattern. I can't recall the name, they are one of the companies that reproduces brake lines. Fine Lines? That's the only company I can think of now, not sure if its them. Do a little searching, see what you can find.
Inline tube The brake plumbing experts
