Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Reload this Page >
Im back!!! Putting the 351c/c6 into the truck!!!Need help with the trans mount.
Old 02-06-2010, 08:26 PM
rtcalabrojr's Avatar
rtcalabrojr
rtcalabrojr is offline
Darksider
rtcalabrojr is starting off with a positive reputation.
Hello again!! I have the motor in where i think is good! It look like the trans would be level with the bottom of the frame. My question is how do you think i should make the crossmember? Sould i use a piece of angle iron and cut the section out and lower it so i could bolt it to the mount?
I tried to search and look up post but nothing really helps. Im sitting here waiting for answers!!! Please let me know Thanks. Im going to upload pics to photobucket of the motor mounts i did.
Old 02-06-2010, 08:51 PM
norvillebob's Avatar
norvillebob
norvillebob is offline
norvillebob is starting off with a positive reputation.
there's quite a few xmembers on ebay, tube and flat style. the one thing to remember is without the original crossmember you wiil get lots of frame flex.
I would suggest a lower member to set the tranny and an upper one to keep the frame from twisting. as the easiest solution. search around there's quite a few different ideas on the board.
bob
Old 02-06-2010, 08:57 PM
rtcalabrojr
Darksider
Im looking to make my own.
I was wondering about the frame flex!! It would not hurt to add one to the top as well.
Old 02-06-2010, 09:03 PM
Jetman's Avatar
Jetman
Jetman is offline
Jetman is gaining momentum as a positive member of FTE.
Have you thought about boxing the frame near that section or would it not be enough room for the brake lines and cables?
norvillebob
I was looking at some channel , I saw on the bay a crossmember with a C-Channel that fit's inside our frame and is bolted top and bottom and a bent tube for the mount..ya follow? Best easiest Idea I've found so far..
Old 02-06-2010, 09:04 PM
rtcalabrojr
Darksider
That could be done as well!! Keep them coming!!!!
Old 02-06-2010, 09:08 PM
norvillebob
Old 02-06-2010, 09:14 PM
rtcalabrojr
Darksider
Hey Bob, i have the second one you listed! But i paid more for mine! I put that in but the trans sits higher. I might cut it up and add metal to cross the frame.
Old 02-06-2010, 11:09 PM
rtcalabrojr
Darksider
Its funny how things hit you sometimes! I took the tranny crossmember i have and just laid it on its side on my welding table and traced it with soapstone. Measured what the drop was on it and was kinda looking at where to cut and weld and so on. Than i said DUH, just put a spacer under the bracket to the frame and there folks we have it!!<a href="http://s919.photobucket.com/albums/ad37/rtcalabrojr/?action=view&current=003-4.jpg" target="_blank"><img src="http://i919.photobucket.com/albums/ad37/rtcalabrojr/003-4.jpg" border="0" alt="Photobucket"></a>
It will be boxed on the ends as well!
Old 02-07-2010, 12:03 AM
Julies Cool F1
Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Ok well let me add a couple things as food for thought.
First, in order to mount your C6, youare going to have to cut out the existing transmission cross member.
This a a very stout cross member and not only supports the transmission, but also provided substantial bracing support to the frame.
You are going to have to replace that support and I'll tell you right off the bat that the tube type transmission supports aren't going to be stout enough to do that. So, you are going to have to either build something to brace your frame in the center and use the tube type just to hold the transmission up, or incorporate the two.
How do I know this? I have a 390/C6 in my 51 and have the tube type mount. One day I was turning around on my sloped driveway to back my truck into the garage. When I shifted out of drive and into reverse to back up the hill, the entire front left corner of my truck twisted and lifted up like I had driven up a foot tall shop stand with it. The guy who does my springs told me I definately needed a cross brace to stabilize the frame. I'm working on it.
In the mean time here are a couple links about this we had previously with pictures. You can see my set up with the tube type transmission cross mount.
https://www.ford-trucks.com/forums/8...on-mounts.html
https://www.ford-trucks.com/forums/8...-51-f-1-a.html
Have fun!
Old 02-07-2010, 12:11 AM
rtcalabrojr
Darksider
Thanks Julie for the heads up! I will be looking intot his in the morning off to bed its way, way past my bed time!!!!
Old 02-07-2010, 08:12 AM
norvillebob
why not add another "tranny mount" or the like to the top of the frame?
Old 02-07-2010, 02:03 PM
the lights's Avatar
the lights
the lights is offline
the lights is starting off with a positive reputation.
I used 2x2 square tubing with off sets to mount my trans it seemed to work out plus it replaced the stock tranny mount. by the way the truck looks good.
Old 02-07-2010, 04:37 PM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
I don't want to sound like the frame police but I think these frames should be boxed front to back, after that, flexing is never a concern, JMHO
Old 02-07-2010, 06:00 PM
Jetman's Avatar
Jetman
Jetman is offline
It is awesome to have so much help and wisdom of members who have already been there done that.
If anyone has information on putting a toploader in a 1951 F1 with a 351C I would appreciate it. This work lies ahead for me.
Freddie
Quick Reply: Im back!!! Putting the 351c/c6 into the truck!!!Need help with the trans mount.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
