Im back!!! Putting the 351c/c6 into the truck!!!Need help with the trans mount.
#32
#33
It may be night and day but i bet the 460 BIG block is bigger there for leaving more room for the 351 Small block but hey thats just my 2 cents.
Also julies, rtcalabrojr has a 55 f100 with the mustang II front end thats why i know he will have pleanty of room without a bunch of fab work. im not sure on the different types of oil pans the 351 has or what motor mounts you will be using like i said i went through 3 different oil pans before it was placed just right, lol.. good luck rtcalabrojr.
#36
I was working on the truck tonight, well the trans mount. I was cutting stock and bending pieces to go from the top of the frame down to the crossmember when im sitting there looking at it thinking!!! Yes scary at times i know. I said before i go any more ahead i go get the power brake booster i bought from CCP and try to fit it in to the correct spot!! Well what do you know it wont work!!! Im pissed and here i am complaining about it. Im still looking for a oil pan for the motor so im thinking i might wait till i get another one and maybe i could lower the whole motor trans combo down? I believe someone said i could get shorter motor mounts, i guess they mean the rubber ones from the motor to the bracket with the tube welded to it. If that makes any sense, o well nite all!!! Ill sleep on it!
#37
Well, don't get discouraged! Yes it's tight, and what's worse is that there's only so far you can go before you have to commit - with the placement of a few components not having been measured.
On my set up (and I used the stock brake master cylinder) there were four components that I had less thaqn 1/4 inch of room to play with. And one of those (the adjustment of the stock column shift rod going down to the transmission) was so tight, that I had 1/2 turn of the adjustment nut of tolerance. If I adjusted the rod that 1/2 turn taller, it would get hung up under the brake pedal. If I shifted into low gear I could not push the brake pedal----that close.
Take your time and use clamps to free fit stuff. Once a component is clamped in start adding on the next item.
You'll get there. But just understand that it's going to be a very close and slow process, and you have to be patient and precise.
If it starts to "fight you" put it down for the day.
Yes, you'll get there.
#38
on
rj,
another suggestion... this is under a 460/c-6 combo I have
Building A New transmission Cross Member For A 1953 - 1956 F100 .: Articles
laster
john
laster
john
#39
michaelshewkin
09-26-2010 09:38 AM
91Ranger40
02-25-2010 06:27 PM
BigBadFord80
04-04-2003 09:36 PM
