The Bud shoot out
Two 1968 390 CID V8 Ford Mustangs (325 bhp) were used for the chase scene, both owned by Ford Motor Company and part of a promotional loan agreement with Warner Bros. The Mustangs' engines, brakes and suspensions were heavily modified for the chase by veteran car racer Max Balchowsky. Ford Motor Company had also originally loaned two Ford Galaxie sedans that were intended to be used in the chase scenes, but the producers found the cars entirely too heavy to put through jumps over the hills of San Francisco without the suspensions of the cars being severely damaged. The Galaxie sedans were replaced with two 1968 440 CID/375 bhp Dodge Chargers that were bought outright from Glendale Dodge in Glendale, California. The engines in both Chargers were left largely unmodified, but the suspensions were upgraded to cope with the demands of the stunt work.
The director called for speeds of about 75–80 mph (120–130 km/h), but the cars (including the ones containing the cameras) reached speeds of over 110 mph (175 km/h) on surface streets. Driver's point-of-view angles were used to give the audience the "feel" of the ride as the cars jumped the hills. Filming the chase scene took three weeks, resulting in 9 minutes and 42 seconds of film. During this film sequence, the Charger loses six hubcaps and has different ones missing in different shots. As a result of shooting from multiple angles simultaneously, and some angles' footage used at different times to give the illusion of different streets, the speeding cars can be seen passing the same green VW bug four different times, and the same blue sedan with black top three times. The Charger also crashes into the camera in one scene and the damaged front fender is noticeable in later scenes. After the Charger hits a parked car, it disappears for a split second from the screen before the scene is changed.
most movie and tv soundtracks are not what is really happening.
this was the case in this movie.
no 8 speed was used.
