Power steering box for 73 4x4 - Ford Truck Enthusiasts Forums
Old 06-21-1999, 10:39 AM
deleontow
deleontow is offline
deleontow is starting off with a positive reputation.
1967 through 1975 Ford F250 4 X 4 gear box will fit your truck. Though you will also have to change the colum as they are different lengh. 1973 thru 1975 F250 4 X 4 with powersteering colum will fit with the gearbox.
Note that it has to be F250 as F150 and F350 will not fit
Good luck Dave
Old 06-21-1999, 06:38 PM
sparky's Avatar
sparky
sparky is offline
sparky is gaining momentum as a positive member of FTE.sparky is gaining momentum as a positive member of FTE.
I recently converted my 73 F250 4x4 to power steering from the power assist option that was offered instead of power steering for awhile by Ford.
If your truck has the same setup mine had, less the power assist stuff of course, like straight front axle with leaf springs, steering gear box is on opposite side of frame from pitman arm, pitman arm hangs down from frame toward the ground and rotates back to front. Check out the technical article on this web site describing how to change from power assist to power steering, it should help you out.
Good luck.
Sparky
Old 06-21-1999, 07:16 PM
ole65
ole65 is offline
ole65 is starting off with a positive reputation.
firedaniel
08-06-2013 08:38 PM
firedaniel
04-21-2013 01:02 PM
danyl01967
1968-2013 Full Size Vans
07-25-2011 08:28 PM
92-150man
08-12-2010 09:26 PM
fastbigblockford
12-10-2003 01:05 AM
Quick Reply: Power steering box for 73 4x4
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
