Chris did they check the universal joints on the drive shaft? They seemed ok when we did the rear swap but looked like they have been on there a few miles. Hopefully the tire balance will do the trick.
im fairly certain they did. but not 100% sure. if the tire balance doesnt fix it im gonna have them check the universal joints. this is getting frustrating. it almost seems that when the truck is cold it does it worse. so idk.
well the rotation and balance helped some on the vibration and shimmy. but not all the way. still gotta get pads rotors and shocks. maybe the brakes will take care of the vibration.
Let the snow begin Should start snowing today and end tomorrow night with 2-5 inches if the weather gurus are correct.
Changed the oil and greased up the front end yesterday but didn't get that bath in like i wanted too. Did clean up the underside to get any salt residue off.
