Ask the engineer for the new 6.2l gas engine!
#481
... Which brings me to my next point following the variable camshaft and cylinder fire hints. A V8 engine (or any engine) now days is essentially 8 individual motors just driving a common shaft. These "motors" can be individually adjusted, shut off, etc. But what has been missing so far is these "motors" don't have to mirror their neighbor any more. This combination of "motors" can be different from one another in stroke, bore, and CR's. Smaller cc cylinders that take less air and fuel can power the vehicle most of the time. The computer can turn on, shut off, random fire, cylinders of different bores and strokes as needed depending on throttle possistion or demanded by the driver with a simple power/eco switch (nothing new there). ...
#482
As far as valves go, I doubt really a 4 Valve head will be made any time soon. GM and Chrysler have both proven that 2 valve heads can flow more than enough air. The main requirement to make a 2 Valve head work though is big valves - which require a big bore. The old 4.6 and 5.4 modular engines simply didn't have a big enough bore to allow for big enough valves.
#483
Regards, Eric
#484
A Super Duty weighs a good 1000-2000 lbs more than an equivalent OBS truck and has much much stricter emissions standards to adhere to.
Yes, it does have two plugs per cylinder. Big bore engines, especially with the pseudo-hemi head design like the 6.2 (and the Chrysler 5.7/6.1/6.4 Hemi) have a harder time controlling combustion and emissions. They could either use a bigger/more restrictive cat, or use two plugs per cylinder.
essentially to say thanks for the info with a simple.
#485
Yeah, that's gonna be one rough running engine. Time for another American standby, the balance shaft! Invented in England, patented to Japan now, and used in cases where a shoddy engine design needs to be smoothed out so it will seem to run like a properly designed one!
Regards, Eric
Regards, Eric
#486
That's all true. Don't forget the 60 degree Duratec based V8 that also needs one too.
I was talking about that non-symmetrical cylinder engine that the other fellows were talking about. I'm thinking maybe they can rig up a balance shaft that will smooth out this crazy engine that would have uneven firing pulses because the bigger cylinders are producing more power than the smaller cylinders are, and also to smooth out the imbalance brought about as the result of the bigger cylinders having bigger, heavier pistons than the smaller cylinders do. The other route of giving some cylinders longer strokes than the others would also bring about imbalance issues, again necessitating the need for some kind of external balancing help from a balance shaft. I honestly don't think it could be made to work though.
In other words, what I am trying to say in a round about way is I don't think this non-symmetrical cylinder engine is very practical.
Regards, Eric
Regards, Eric
#487
Interesting point about cylinder sizes. I'm sure it's possible but the real question is whether it's feasible in a vehicle. Cars and trucks are getting more and more expensive every year as the technology advances. The side effect of such advancement is cost, as more sophisticated technology costs more. A complex engine with varying displacement per cylinder would be MUCH more complex and expensive than the current offerings.
The other problem I see is that parasitic loss is still going to be there. Whether or not the cylinder is firing, it WILL be along for the ride. Meaning it's still causing friction and pumping losses even when shut off. Heck, you could use a system like Chrysler's MDS which closes off valves and you'd STILL have lots of friction losses.
Yes it would be more expensive but since trucks cost more than a house already why not shoot for the moon?
Yes there is also parasitic loss but at speed it isn't very much. Right now it is possible to make a V8 run on only two cylinders dragging the others along. But the loss is minuet compared to the gain of not feeding those cylinders with fuel. But what would be really neat and even more expensive is if you could uncouple the "extra" cylinders from the rest of the motor which would mean no friction loss. But that is even more far fetched of happening than a variable CI motor. Also ALL 4 cycle engines have parasitic loss wasted on the exhaust stroke. It is a small amount of loss but it is a loss after all. This loss can be seen in the differences between a 4 cycle engine and a 2 cycle engine. I think you said fords new 6.2 V8 engine puts out something like 332hp. In the 2 cycle world it only takes 100 pounds and 3 cylinders to bypass that. PSI builds big bore kits for polaris snowmobiles that are just insane both in HP numbers and price. Take a look at this little 360HP 3 cylinder: PSI Engines
Now just imagine someone was able to valve a 2 cycle or fire a 4 cycle every revolution to eliminate the wastefull exhaust stroke.
YouTube - Honda F1 motor test
Also remember fords failed attempt with the hybrid ranger/explorer that was a strait up hurry up and get it out there copy of hondas insight and toyotas prius. They just did it with a compact truck chassis to try and be different.
My kids are up now and I can't think with all the noise any more. I believe I am starting to ramble on so I'll quit for now. These are great healthy conversations here! I love it!
#488
<style type="text/css">p { margin-bottom: 0.08in; }</style> Your ideas are fascinating but perhaps not easy for full scale implementation. Lets say that you have e.g. 7 or 8 or 9 non-symmetrical cylinders. When you need full power/torque it will be difficult to minimize vibrations and perhaps other ill effects.
Each cylinder/piston rod combo would be balanced to its own flyweights on the crank. The only thing that could cause a shake is the "missing" of cylinders when they are shutoff. However this could be taken care of with some careful planning of which cylinders are fired when. Remember it doesn't have to be the same 2, 3, 4, etc cylinders fired all the time. The computer can control random firing of random cylinders when need be to smooth out the miss fired cylinders.
#489
Most of that minus the gas guzzling monster V8 can be found in old hondas. When I say old I mean as far back as the late 80's early 90's. PSD's are another story. We will see how fords new diesel will hold up over time. Not so much a production motor but if you want to talk technology advanced big V motors just look at F1 cars. Who powers all the F1 cars? It sure isn't fords stone age V8's.
[QUOTE=SnowseekerThis can be looked at two ways. One saying yes efficiency is being hindered by the quest for more hp but at the same time hp is a byproduct of efficiency. In fords quest for big hp numbers to try and keep up with the other guys efficiency comes after hitting goal hp numbers. If gas mileage was the number 1 goal you wouldn't see the hp numbers you are seeing, they would be much lower. [/QUOTE]
In this day and age fuel economy IS the priority. Look at the new 2012 Focus: Same 2.0L engine, but with direct injection and a healthy horsepower increase from 130 to 160 horsepower! EPA numbers not released yet, but I'm pretty confident there's a healthy increase.
#490
Look at engines such as the Boxer 6, or the Inline 6. They have perfect primary and secondary balance without the use of balance shafts. This is because the way the counter weights are placed along the crankshaft, they cancel each other out. This is just not possible with the engine design you are proposing.
I'm also not sure what an F1 engine has to do about anything. You do know that Honda isn't the sole supplier of F1 engines? Ford-Cosworth even had some offerings at one point. You do also know that F1 engines are not allowed to use VVT/VCT, variable intake runners, etc...F1 engines are very low-tech compared to modern automotive engines. The only thing worth noting really in an F1 engine is the metallurgy and the valve train.
As far as Honda having all the technology the 6.2 does back in the 80s/90s - also not true. Honda had V-TEC since '89, which only switched between two camshaft profiles. They didn't add variable valve timing to the mix until 2001.
#491
2006 Honda Ridgeline Long-Term Road Test | Vehicle Reviews Blog & Discussions at Truck Trend Magazine
To me honestly that is kind of sad. The B16A vtec motor (1.6L) in my 1989 honda civic puts out 170hp and gets 35mpg religiously. The new 2011 honda civic 2.0L dohc vtec engine puts down 197hp. All while getting equal or better gas mileage of the competitors. I know it sounds like I am biased toward honda but I kind of am. How can you argue with more hp, better mpg's, and better reliability?
Every now and then I take stuff personally. I try real hard not to and have to tell myself to calm down some times but every now and then it gets out. I have gotten much better at not letting things bother me as much as they used to. I have learned that no matter what I say some people will not change their thoughts on some matters. Even when I know I am right I have learned it is best to just stay quiet and not get involved with some discussions/arguments. I am always up for a good intelligent conversation about mechanics though! I love this stuff! Hope this is still fun for all.
#492
Not so much a real truck but hondas ridgeline has a "high tech" motor. Coincidentally the same motor that is in my honda odyssey mini van. Funny story. Last year the wife and I were on the way back from a night out. I pulled up to a sto light that was red. This intersection is on a one way road, from the light the road goes from 3 lanes down to 1 within 1/8ish mile. To my right a guy with a convertable BMW pulls up with the top down. A guy in his 50's with his (what looked like to me) high maintenance wife sitting in the passanger seat. As we were waiting for the light to change I could tell he wanted to get out ahead of me before the single lane by the way he was inching forward and watching the opposing traffic light. Well the light turned green and I left the light like I normally would. I noticed the BMW left a little hard and was on a mission. So being a guy I floored the little 3.5 vtec mini van and the tires let out a slight screech. The BMW's back bumper was even with my front bumper at this time. To my amazement and my wifes fright we were slowly pulling on the BMW! When we got to the single lane my front bumper was even with the BMW's drivers door. The other driver had to let off and fall in behind me on the single lane road. At the next stop sign two blocks up the road I took a right hand turn and watched my rear view mirror. As the BMW driver went strait I could see he flipped me off. His wife looked as though she was smilling. I would have loved to hear the conversation that followed in that car. I couldn't believe the BMW didn't have it over the measly mini van. I LOLed.
The 2012 Focus is an economy commuter car, and this engine is the base option for the car. Compare that to the Civic's 140-HP base engine and I think it's pretty impressive.
The 2012 Focus ST will have an EcoBoost 2.0L engine making nearly 250 HP!
#493
But what are you comparing it to? Your expensive, high-feature 4-cylinder is the premium engine option for each of those cars. And they aren't cheap.
As far as the ecoboost motor I would say it is average. It is easy to make hp numbers with a turbo. Honda does it NA which I find way more impressive. 100hp+ per liter NA is amazing. But if the rumors are true that might change as well.
Normally.
#494
It doesn't work like that. You can't think of an engine as a bunch of single cylinder engines - you have to think of it as a whole. You would have a crankshaft with a bunch of different size counterweights swinging around. It would be a huge vibrational mess. It is not possible to balance out all the vibrations of a specific cylinder with just counter weights.
If you take three different sized balanced motors and hooked them together you would have a single balanced motor.
There is/was more to gain from the variable cam lift, duration, and timing (yes vtec does all three) than the simple degreeing of the cam(s). The new honda motors do it all with multiple stage cam control. Pioneers that others try to imitate. Ford, chevy, and dodge all stick their money into marketing, honda sticks their money into research and development.
#495
Balance shafts are a bandaid. They are not needed if proper research, testing, and tuning are implicated. This very thing can be seen between mitsubishis I4 2.0L used in older eclipses, lasers, and talons and now used in evolutions which all use balance shafts to try and smooth out the outdated technology cast iron motor. Now honda with the same basic I4 has NO balance shafts and runs just as smooth if not smoother than the mitsu motor. Why does one use balance shafts and not the other? Wierd isn't it.
Because only the best are chosen to build F1 engines.
Honda is far from the best - and my dirtbike that is in pieces right now for a piston replacement is proof of that.
