Where exactly is the easiest place to find the PCM code?
I had a few minutes this afternoon so I thought I would go ahead and try to locate the PCM code so I would have it for when I eventually order my chip. I successfully located the PCM, but the only "label" I could see was on the side of the PCM, just inside the plug in the engine compartment on the side towards the driver's fender. I began the process of unscrewing the bolts so I could see it, but getting to the bolt that holds the plug on was quite difficult. I ended up stopping because I was running out of daylight. Is there anywhere else to look for the code without having to unplug and remove the PCM?
Thanks for the help.
Dwinn
Computer Chips & Tuners
10-07-2005 10:01 PM
