IAC on my 4.0
It has been a long time since I have cleaned one, but I think I used purple cleaner. The PB Blaster is just as good, but I', not sure about the brake cleaner and WD-40. I think I used alcohol as a final clean and let it air dry. Never had it stick after cleaning.
The only thing I can think of is checking the manifold pressure to see if it is high enough to work the valve.
