home made gooseneck hitch.... - Ford Truck Enthusiasts Forums
Old 02-01-2010, 04:23 PM
fordguy_460's Avatar
fordguy_460
fordguy_460 is offline
fordguy_460 is starting off with a positive reputation.
i have a buddy that has a 1987 f250 4x4 6.9 diesel 4spd ext cab long bed he is wanting me to build a gooseneck hitch/plate for his truck and was wanting to get some ideas as well measurements and what materials to make one..any and all info is much appreiciated!
Old 02-01-2010, 06:48 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
Hitch goes 4-6" forward of the rear axle in the center of the bed...
30,000# is a good rating to shoot for... which means up to 6,000# of tounge weight.
Old 02-01-2010, 09:57 PM
fordguy_460
thanks TexasRebel
Old 02-02-2010, 12:01 AM
rebocardo
rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
You probably should run 8" w x 3/8" thick C-channel from frame rail to frame rail for the ball mount. (3) 9/16" grade 8 bolts each side should be good enough to hold it. You could go to 3/4", but, drill bits are expensive and probably takes too much of the frame flange. I would back the underside of the frame with a 1/4" plate
Old 02-02-2010, 07:23 AM
fordguy_460
thanks rebocardo
Old 02-04-2010, 03:00 PM
Cowboy65's Avatar
Cowboy65
Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
Just a word of caution, if something happens to your buddy or he sells the truck and something happens to the new owner you could find yourself in some hot water. Personal liability lawyers love to sue the pants off of people for this kind of stuff.
Old 02-06-2010, 08:57 AM
fordguy_460
i accually never thought of that side of it Cowboy65...thanks for bringin it up....i will deffinatly keep that inmind...but dont think ill have to worry about the hitch anytime soon hes had the truck for a week and it already took a dump on him with no real resolution to the problem....thats the worst part about buyin a "used" diesel you dont know what you might run into....so thats were we are now.....thanks for all the info though!
rbrockman
Fifth Wheel & Gooseneck RV Towing
05-06-2017 03:42 PM
Rheingar
32
03-10-2017 01:04 PM
banks0531
12-17-2014 06:12 AM
woodbutcher85
1999 to 2016 Super Duty
11-12-2011 11:16 AM
horsepuller
03-31-2002 07:14 PM
Quick Reply: home made gooseneck hitch....
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
