new owner with some questions
Sup guys its been months now since i join the forum and after a while yesterday i finaly got what i was looking for 2005 F250 super cab in what looks like good shape and price also . so here is a few things i would like to know if anyone can answer
1 i only got one set of keys if its just a simple key (with no ship)how can i know if i can program a remote?
2 when i pump gas the pump wont stay runing it keeps stoping .I notice that there is a small metal clip or door thats in the hole thats not there how can i replace it?
3 the rear small doors close fine but the two front doors dont look even when they are close the top of the door seems ok but the bottom its a bit more separate and they feel a bit lose how can i adjust the doors?
there may be more things but this are the ones that i have in mind now.
the lot i got the truck from will fix all this details but i always like to know how its done .Dont know how to post pictures here so far .. thanks in advance ... Tony
Fuel pump shutting off while filling. Read this thread your answer is there. It's an easy fix if you don't have a warranty. Your time will pay for the parts instead of paying someone else.
https://www.ford-trucks.com/forums/7...-5-4l-gas.html
Someone else probably will come along and try to help with your other questions.
Download your owners manual here for free:
http://www.motorcraftservice.com/vdi...pageid=&gutsid=
2. Is this truck gas or diesel? Diesels do not have the little metal door. If you have a gasser, the previous answer is a good one.
3. Can't help you on that. I assume the doors need adjustment. A bodyshop might help you with that for very little cost.
I just bought a 2006 F350 XLT Super Crew. Since my truck had been a repossession I only got a ignition key that the dealer had made for the truck. I had an extra key fob from my 01 F150. I had spare keys made at Walmart. Following the owner's manual I was able to program the 01 F150 remote to my F350. It took me about 5 minutes to reprogram the remote. I was able to track down the previous owner last week and he gave me a the original Ford key and another remote.
He may very well have another key. But he doesn't know my last name nor where I live. And I'm over 50 miles away. And if someone wants to steal my truck, or any vehicle for that matter, having a key or not isn't going to keep them from stealing it.
Furian:
New to the site and am having trouble finding SD guys with the 5.4 L. Seems like most have either PSD or V10, probably what I should have done too. Do you feel like you gained a lot by doing the Tunning and Air Intake? I'm thinking I def need more power than this thing is giving me right now! Thanks for any help.
Furian:
As for the CAI kit, that's depends... If you plan to install a high flow exhaust system, then you will notice a difference with the CAI kit. However, if you plan to keep the OEM exhaust or just change the muffler, then the CAI kit won't really help much. My original plan was to install new long-tube headers, high-flow cats, and dual exhaust. I'm still going to do this upgrade but now I'm also going to install a Whipple supercharger. The Whipple supercharger has its own CAI so my K&N CAI will not be used.
Here is the thread on the Whipple supercharger:
https://www.ford-trucks.com/forums/8...uper-duty.html
One other thing that can help performance is having the proper axle gears, depending on your tire size.
Finally, check out this thread regarding performance upgrades for the 5.4L 3V engine...
https://www.ford-trucks.com/forums/8...-for-5-4l.html
ok once again thanks alot for all the answers . now yesterday my check engine light went on and the code that i got was P0430 after some googling i see that in must cases its a bad catalys converter but for some reason the computer also mentions missfire , vacuun leak,engine oil leakage into exaust valve . so where should i start? i took a quick look under the truck and i notice that there are parts on the exaust and the catalys that have lots of rust . should i just take everything out and replace it or test for other things ???? the lot i got the truck from told me that they would fix things for free only for the first 30days i got the truck with no waranty at all but after i saw the guys there do the tuneup last sunday i dont like the way they did things and since i dont mind doing things myself when it comes to cars i would like some advise i already so the prices and i really dont mind but again i dont want to spend money until i track down what the problem is? once again thanks alot in advance .
Tony ...
Tony ...
