I have a short wide bed 2003 F150 and the headlight adjustment seems to be to low. I can find no way to adjust the height like the older Ford's. Any idea's? Thanks, Charles
you have to remove the housings. Pull the tabs up and slide them out. then you will see the little adjustment screws on the mounts. May have to take them out a couple times to get them where you want. Mine were a little low, and of course the owners manual says they're not adjustable. When I took them out to replace the bulbs and polish them, I discovered how to adjust them.
