Valves in a 1979 400
In my quest for getting the power out of my F-350 400 engine, I have been seeking information. The engine has 93K miles on it, runs well, and shows no sign of problems other than being a California smog engine. I am in the process of installing a mechanical oil pressure guage to check out the bottom end, and have a Cloyes double roller cam gear/chain set to bring the cam to TDC instead of retarded 6 degrees, and plan on finding a header/ exhaust system to improve flow. I was told by a mechanic that this engine has two piece valves that tend to come apart after the 100K mark. Is this a problem I should worry about? Probably aftermarket aluminum heads would cost little more than rebuilding these heads to prevent the possible problem, but the added cost will move the finish of the project out a while. If the heads/ valves problem was exaggerated, I wouldn't have a problem using these heads. Any solid info would be appreciated. Thanks
on
I wold say these valves are more prone to coming apart at high RPMs verses high milage and the 400 really doesn't like RPMs any way. I don't think the stock valves are near as bad as their reputation, but some times its better to be safe than sorry. What are you doing with this engine? If you are running a stock cam and intake/carb I think you will be fine the power band will still be low. Plenty of these things have been running for 30 years with out breaking a valve. I have switched every motor I have every rebuilt to single groove one piece valves but I am paranoid about such things. Really its up to you and how you thing you are going to run this engine.
-Johnboy
-Johnboy
Thanks for the reply and help. I intend to keep the milage low, probably 5,000 miles per year, most of it highway. I have never taken the engine over 3900 rpm, and then only when down shifting. On the highway I have usually kept it at between 2400 and 3200 rpm. I intend to put on 35" tires [or so] to keep the highway rpms down to around 2500. I may try for a Edelbrock 4bbl intake as was recommended for better gas milage. I will also port the distributer directly to the engine vacuum to avoid the smog delays with the carb and EGR porting. If I need to change out the heads, I will go with aluminum after market heads, but I would just as soon keep the expense to a minimum so I can afford more gas.
I have been reading my factory manual, and in the smog section it indicates both the carb and the egr have spark advance delays and retardation to pass emissions. How do I port the distributor to get standard spark advance? And do each of you agree that the two piece valves are OK? Thanks for the help.
stock 2 piece valves are NOT ok unless you're looking to scrap the engine at some undeterminable point in the future.
here's a rundown on how to set up for manifold vac advance
Cleveland Links!: How I use manifold vacuum for advance (posted here so I can find it)
here's a rundown on how to set up your mechanical advance, Ford point distributors are the same below the breaker plate, don't miss the second page
Duraspark_distributor_recurve_instructions_index
fordfan28
07-28-2006 07:54 AM
beensack
05-30-2006 10:02 AM
