04 FX4 F150 Electric prob..HELP!!!
Problem: radio said "phone". i pushed the mute button,nothing happened. radio does not work. I turn on the headlights,radio works.I turn the truck off,radio still says "Phone". battery went dead a day later. I put the key into the ignition,turn it on and i hear,what i assume,is the fuel pump.but everything else is dead. turn off the key and i still hear the same clicking noise. is this a relay???? if so,where do i start??? i do not have a schematic. I need real help. I can not afford to go to the dealer or anyone else. no job. thank you. R lynch
Can you put a battery charger on it and then see how everthing is working? Besides a bad cell it can also be dirty or corroded battery connections, not just at the battery but also the other end of the cables. It also could be a relay that isn't releasing and draining the battery, when you turn off the power. I had that happen in an Explorer a few years back. Keep us posted.
btacarlton
2004 - 2008 F150
17
02-10-2009 04:50 PM
jetpilot1
12-13-2008 08:04 PM
Jerry Blair
08-25-2003 08:53 AM
