Update on work done
Old Feb 3, 2010 | 10:16 PM
  #46
jefxxo's Avatar
jefxxo
Originally Posted by Dave Sponaugle
Actually I just finally saw the low vacuum sensor where I was not expecting it to be.
The wire connector is what made me recognize it.
Then I saw the thicker front plate, and noticed no hose out of the back.
Quick visual 3D calculation said if the hose in question was routed below the other vacuum line, It will reach the nipple on the low vacuum sensor.
Heat and oil along with the tight radius may be why the hose slipped off the nipple to start with.
21" monitor helps as well, no microscope needed.
I'm going to take a look at it tomorrow. But I did notice something. That nipple is broke off in the hose. Ill be back with what i find.
Old Feb 4, 2010 | 10:46 AM
  #47
WarOzz's Avatar
WarOzz
If the nipple is in the hose you will need to replace that low vacuum switch, snuff can looking thingy. I would suggest mounting it someplace else when you replace it so that it's not so close to the steering arm. Mine is on the drivers fender down below the battery, can send you a pic of mine if you want.
Old Feb 4, 2010 | 11:03 AM
  #48
WarOzz's Avatar
WarOzz
I had to go out to the truck anyhow so I went ahead and snapped a picture for you. Mounted to drivers side fender right below the battery box.
Old Feb 4, 2010 | 05:48 PM
  #49
jefxxo's Avatar
jefxxo
Yep thats were it goes. ( Nice one Dave! ) But it is broke off. This a dealer part?
Also It is mounted about 6 inches from the steering. There is no way that it was touching. That ring where it was clean is a fluke. I guess I should do some cleaning also. Whew thanks for all the help guys!!!
Old Feb 4, 2010 | 08:39 PM
  #50
Dave Sponaugle's Avatar
Dave Sponaugle
I looked through Advance Autos online parts, they do not show one.
So I am going to guess Dealer only part.
They don't usually go bad, so a salvage yard would be a decent source as well.
If you have to drive, cap the line off.
Unplugging the electrical connection may turn the brake light off as well.
Old Feb 4, 2010 | 09:59 PM
  #51
jefxxo's Avatar
jefxxo
I tried advance and auto z. and Oreilly. With no luck.
I did cap it off. Ill unplug it and see what happens.
Old Feb 5, 2010 | 10:55 AM
  #52
jefxxo's Avatar
jefxxo
Called the dealer, its called a low vacuum warning switch Assembly. $82.53. Im going to check the salvage yards!
Old Feb 5, 2010 | 10:58 AM
  #53
WarOzz's Avatar
WarOzz
Did you happen to get the dealer part number? If so you might find one on ebay.
Old Feb 5, 2010 | 04:34 PM
  #54
jefxxo's Avatar
jefxxo
No I did not. Ill try and get it. I did find one at a local parts store for $53. Junk yards tomorrow.
Old Feb 5, 2010 | 05:33 PM
  #55
starmilt's Avatar
starmilt
Get the part number and I can see if its the same as an 86 or 88.
Old Feb 5, 2010 | 09:56 PM
  #56
Dave Sponaugle
Looks exactly like the one on my 86, and since it is doing the same function on both trucks, my guess is they are the same.
Old Feb 7, 2010 | 12:03 AM
  #57
jefxxo's Avatar
jefxxo
I'll get the part number tomorrow. But I did unhook the wire clip going to it and the light went off.
Old Feb 7, 2010 | 07:03 PM
  #58
Marianna2003's Avatar
Marianna2003
Since you are doingwithout it anyway, Why don't you try to JB Weld it back together? Take a small piece of tubing - Pssibly out of a ball point pen and do what you have to to get it to work. I mean it's not going to hurt anything if it doesn't work and you might save yourself a trip to the junkyard.
Old Feb 7, 2010 | 11:24 PM
  #59
jefxxo's Avatar
jefxxo
The parts store was closed today. So ill get the number tomorrow.
Mari, I was thinking the same thing. Ill pull it of in the morning and see what I can do with it.
Old Feb 15, 2010 | 02:59 PM
  #60
jefxxo's Avatar
jefxxo
finally got around to getting the part number. it is "E3T212A182H" its a motorcraft part.
jetact
Mar 30, 2015 10:27 AM
jetact
Sep 14, 2010 09:30 PM
DanMan7
Jun 23, 2007 11:47 PM
JBronco
1978 - 1996 Big Bronco
25
Nov 30, 2002 05:50 PM
