Update on work done
Old Jan 31, 2010 | 03:15 PM
  #31
starmilt's Avatar
starmilt
I'm pretty certain it does but don't have one, and it has been years since I have been under the hood of a 93-4 model so I can't say for sure. lol
Old Jan 31, 2010 | 10:28 PM
  #32
jefxxo's Avatar
jefxxo
Well I got a good laugh. I figured I would start from the beginning. And try to figure out why the cruise control was not working. And when I looked at the throttle cable here is what i found.
I should have looked at this first.
Old Jan 31, 2010 | 11:25 PM
  #33
Dave Sponaugle's Avatar
Dave Sponaugle
That looks like a "Huston, we have a problem".
Old Feb 1, 2010 | 12:37 AM
  #34
jefxxo's Avatar
jefxxo
I would still like to find out where this vacuum line goes. I searched all over and cant find anything unplugged.
Old Feb 1, 2010 | 10:16 AM
  #35
Rick Wallace's Avatar
Rick Wallace
Find someone that has the same truck and ask them can you look at theres..Or just plug it off
Old Feb 1, 2010 | 10:26 AM
  #36
starmilt's Avatar
starmilt
Warrozz posted where it went on his pickup. Has the vacumn cannister been removed off your truck.
Old Feb 1, 2010 | 10:47 PM
  #37
jefxxo's Avatar
jefxxo
I looked around and don't see one or should I say feel one. It was dark so ill try and look better when I have more light. I plugged it off for now.
I tried to attempt to fix my brake light (dummy light). I pulled the wire going to the Ebrake, no change. So I shorted it on a ground still no change. So I left it unplugged. Every now and then the light will flicker on and off, plugged in or not. Does this wire run straight to the dummy light? All I can see is it go into a piece of cable wrap.
Old Feb 1, 2010 | 11:21 PM
  #38
87crewdually's Avatar
87crewdually
Check fuse #17.
Chack brake fluid level switch on the master cylinder resevoir, if you have one.
Check the vacuum warning switch. It's usually on the passenger side wheel well near the battery. It's round with a vacuum line and a few wires in a plug on the end of it. I believe I saw it in your one picture but it was under the master cylinder on the wheel well. If there isn't adequate vacuum at this little round switch, it will turn on your brake light on the dash.
Old Feb 2, 2010 | 07:42 AM
  #39
WarOzz's Avatar
WarOzz
That switch that 87Crewdually is speaking of is were your vacume line goes! Mine T's off, one end to that switch the other to the cruise control can.
Old Feb 2, 2010 | 07:36 PM
  #40
Dave Sponaugle
I see where it goes.
[/quote]
Move your finger straight down.
That round snuff can thing with three wires going in the side connector.
On the motor side you will find a nipple the hose goes on.
That can is the low vacuum switch that turns the dash light on.
With no hose on it, the light should stay on constantly.
And that hose being off, is a vacuum leak.
Mine is on the passenger side, I missed it under the mastewr cylinder till I looked at the pictures again this evening.
And I think I even see the end of the nipple in the picture.
Look at the darker stripe on the steering column.
Then look 1/4" toward the cab and 1/2" right, see the nipple?
How close is the steering column?
Any chance it rubbed it off, and that is where the shiney clean spot came from?
Old Feb 2, 2010 | 09:26 PM
  #41
WarOzz's Avatar
WarOzz
Wow Dave did you look at the pic under a microscope? lol
I am pretty sure your dead on though... glad my snuff can looking thingy is mounted up by the battery.
Old Feb 2, 2010 | 10:34 PM
  #42
starmilt's Avatar
starmilt
Well I seen that there but mine is on the fender well on the other side. It would be nice if they left things where they were. lol.
Old Feb 3, 2010 | 05:34 AM
  #43
FORDF250HDXLT's Avatar
FORDF250HDXLT
my beautiful art work lol.
i dunno if thats right either haha.looks like the nipple tho?
Old Feb 3, 2010 | 05:40 AM
  #44
Rick Wallace
Dave is the man! I looked at that pic several times and never saw that! XLT does nice art work!
Old Feb 3, 2010 | 08:26 PM
  #45
Dave Sponaugle
Actually I just finally saw the low vacuum sensor where I was not expecting it to be.
The wire connector is what made me recognize it.
Then I saw the thicker front plate, and noticed no hose out of the back.
Quick visual 3D calculation said if the hose in question was routed below the other vacuum line, It will reach the nipple on the low vacuum sensor.
Heat and oil along with the tight radius may be why the hose slipped off the nipple to start with.
21" monitor helps as well, no microscope needed.
