Clutch Pedal is soft, Doesnt return all the way
91 F-350 5.8 Concentric Slave....... Installed the new trans and a known good slave and master cylinder (tight budget). The clutch pedal won't return all the way up and the clutch is not throwing out all the way making it impossible to even safely move the truck. Does this sound like a faulty master? If so how does that quick disconnect fitting come apart, I can't seem to pry it open.
You remove the cap and rubber cup from your clutch master cylinder and fill the master cylinder completely full with Dot 3 brake fluid if that is what your truck calls for and leave the cap off so as not to create a vacuum lock. Then crawl under the truck and open the bleeder screw on the slave cylinder. Wait until the fluid starts flowing out and watch that the master cylinder never runs dry. Let a good amount of fluid flow through, again watching so the master cylinder never runs dry, adding fluid as necessary. When you think it is bled good close the slave cylinder bleeder screw and hopefully you will have a good feeling clutch pedal. Top up the master cylinder to the proper level. If you have just a partial pedal so you can drive the truck, drive it a while and repeat the process if necessary.
This has always worked for me.
KHflatbed
05-08-2017 03:33 PM
reamer
10-15-2016 02:39 PM
john.clark
13
10-12-2015 03:14 PM
Gword256
01-26-2010 04:27 PM
