351 intake
Old Jan 25, 2010 | 10:01 AM
z1121jack's Avatar
z1121jack
351 intake
Question. I was about to install a stock intake manifold ON s 351w when I noticed a possible problem. The stock intake manifold and the gasket have a different number of holes they all line up correctly but there is one opening at the rear of the gasket that has no corresponding hole on the manifold. One side of the manifold has a hole that is plugged (rear hole) while the other side has no hole. both gaskets and heads have holes in that position.
Does that mean anything?
Old Jan 25, 2010 | 12:17 PM
Conanski's Avatar
Conanski
Sounds like you have an newer intake manifold(12 bolt holes) and older heads with 16 bolt holes, is that correct?
Old Jan 25, 2010 | 01:18 PM
z1121jack's Avatar
z1121jack
sorry, I had to count holes acording to my count it is just opposite from what you said16 bolts=manifod 12bolts=head
Old Jan 25, 2010 | 02:40 PM
Conanski's Avatar
Conanski
OK... you going to have to plug the 4 extra holes in the intake that are 1 place in from the 4 corners or you'll have a nasty water leak. Your best bet here is to tap the holes and put some pipe plugs in there with thread sealer.
Old Jan 25, 2010 | 03:09 PM
z1121jack's Avatar
z1121jack
can I just put an after market intake on with 87 heads? I was planning to add aftermarket heads later but I have these that have been ported. Will the stock (ported) heads work until my budget wll allow me to add after market heads My budget is suficant to purchase an alum. intake now but not the heads
Old Jan 25, 2010 | 09:49 PM
Conanski's Avatar
Conanski
Yes an aftermarket intake will be fine.
bigred177
23
Nov 4, 2023 07:10 AM
kramttocs
16
Aug 21, 2016 11:25 PM
hooler1
May 16, 2014 11:47 AM
Fredf250
15
Mar 14, 2014 02:24 PM
fiveofsevin
Oct 7, 2013 09:44 PM
