203* thermostat, Anyone have experience with?
I have wanted to do this with my 6.0 in sig. In winter mine runs 185 with winter front in the city and about 195 on the highway with winter front. I would like to see her run a bit hotter, better mileage, better complete combustion. Trick is, I think the low fan comes on around these temps, so I dont know how well it will work.
In a hot climate, going up on t-stat temp would be disastrous.
In a cold climate, going to a hotter t-stat would probably not harm the motor, but would give you a little more "headroom", much like putting in a 180-degree stat in July in TX.
You'd have a little more heat in the heater, the engine wouldn't run QUITE as cold (an issue when the engine will air-cool under little to no load), wouldn't cool off after shutdown quite so fast... The benefits are incremental. No jaw-dropping, eye-popping changes will be substantiated.
Just don't do it in a region where temps get over freezing (32*F/0*C). Base engine temps 10 degrees hotter, anywhere below Interstate 80 (i.e. 2/3 of the continental US), will cause more problems than it will solve.
-blaine
-blaine
tbear853
11-27-2016 11:05 AM
bigb56
07-04-2016 10:18 AM
Talyn
05-09-2016 10:33 AM
