Found a 1956 marmon herrington truck!!
Old 01-25-2010, 12:34 PM
WALFORD'S 56
WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
The frame and suspension and driveline will all be saved. The cab will be removed and all the gauges and emblems be installed in a nicer cab.
My diesel buddy wants to help me out....and will make some decisions of to sell the good parts as a whole....or restore it with my 56 f600 as a donor vehicle.....Bill
Old 01-25-2010, 12:45 PM
rb48f6's Avatar
rb48f6
rb48f6 is offline
rb48f6 is gaining momentum as a positive member of FTE.
Hillbillydeluxe~
I don't have any hands on experience with the MH axles so don't know the ins and outs or pros and cons. I don't know what type of trailer you have or what weight rating it carries. The front axle should fit a typical flatbed okay, my trucks apart but going from memory I think it's about 70" os to os on the front tires. And that should fit between most trailer fenders. If you have duals on the back, pending trailer width the outside duals could be hanging in the breeze. What would be a concern is the carrying capacity of the trailer. A 7,000# trailer only has a bout a 5,000# weight capacity these trucks go well beyond that. Especially an MH with the extra weight of the transfer case, front axle and shaft.
Old 01-25-2010, 02:53 PM
2many56s
2many56s is offline
2many56s is starting off with a positive reputation.
I just love them M-Hs Bill. Its too bad its a big job, I would assume the front axle is too wide to fit under a f600 correctly? Since your currently in florida, are you going to haul the truck all the way home to ohio, or you going to keep it in florida?
Old 01-25-2010, 03:50 PM
WALFORD'S 56
I am not sure at this point in time.
I would put the f600 cab on the marm frame and go that route....and much easier.
Thanks
Bill
Old 01-25-2010, 04:33 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
My F600 MH rode real nice when I was hauling my big window on the back, actually it rode and drove nice all the time just max speed was 50 MPH.
If you had time to burn it was a real JOY to drive, 40-45MPH was a lot of fun!
I think the larger F700-900's look stupid with the wider frontend sheet metal to cover the wider front axle, the F500's and F600's are way better looking.
Old 01-25-2010, 07:20 PM
HillbillyDeluxe81
HillbillyDeluxe81 is offline
HillbillyDeluxe81 is starting off with a positive reputation.
Rb48f6: Weight won't be a problem, trailer is rated at 10,000 lbs. The truck looks big, but I'd almost bet the thing weighs less than my F-150......except for the the 3000 lbs of iron welded and bolted all over the thing. You're correct about the width, the thing is WAY narrower than I expected. Thanks for the info! I'll post some pics in a few days when I get the thing loaded up.
Old 01-26-2010, 07:44 AM
petey shoes
petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
i just happen to have a complete spare driveline for 1.5 tonner, mh! as i'm contemplating selling my truck, i might consider letting it go. looking forward to seeing this truck.
Old 01-26-2010, 09:57 AM
WALFORD'S 56
Petey....sale pending. I got a deposit yesterday....and made a little on it .
Where is your m-h driveline located ..so I can tell him about it?
Bill
Old 05-25-2012, 03:04 PM
56fordf6004x4
56fordf6004x4 is offline
56fordf6004x4 is starting off with a positive reputation.
I have a 1956 ford f600 with a MH conversion. I have been working on it for a bit now. I wonted to know what you guys think on something for my truck. What do you guys think about lifting one of these old 4x4's. For play and not every day driving. Give me some ideas thanks.
Im new here so it my take me a while to respond, thanks.
Old 05-25-2012, 03:25 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
First, welcome to the group, and thanks for saving an old M-H. I'm having a hard time seeing where the benefit is to lifting one of these more than stock. They weren't really designed for rock crawling in the modern sense, but more were designed for off road service on terrain that a normal truck couldn't handle. I'd leave it as designed by M-H if it was me. Stu
Rocketgs
06-01-2016 06:19 PM
POS-F500
80
10-05-2012 03:55 PM
armyaviation
08-28-2012 08:53 AM
Shako49
29
08-20-2011 05:36 PM
Rock Chuck
08-20-2010 01:57 PM
Quick Reply: Found a 1956 marmon herrington truck!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
