Tail light, Parking light, Running Light, Dash Light Problems
#136
1993 Ford E350 Class C Motorhome
Found this forum looking for answers for my issue. Hopefully someone can help me out here..
My issue is my running/parking lights stay on after turning engine off. The only way to turn them off is by disconnecting the battery.
1st thing I did was clean and replace bulbs in marker lights. They are now all working but the front yellow ones are dimmer then the rest. Still didn't shut off.
2nd Pull headlight switch. Lights didn't shut off.
3rd Put a new 4way trailer plug in. Still won't shut off.
4th Changed the Headlight switch connector. Still won't shut off.
5th Changed the Headlight switch. Still won't shut off.
6th pulled the fuse for the marker lights. They finally shut off but not the running lights.
7th pulled some relays. running lights still on.
Please help if you can. Thanks!
#137
#138
I did notice the light switch getting hot rather quickly. Maybe that just cause it was out and I could feel the heat. I have herd that the relay maybe stuck. My problem is that I need to figure out what relay it would be. I thought that by pulling them I could narrow it down. I'll search a little. Thanks.
#140
#141
This thing is really driving me bonkers! The more I read the more confused I get.
Its gotta be down to the relay or a grounded out wire somewhere.
Ok, so I pull a 10 amp fuse in the power distributer box and the clearance /marker lights go off. Now just the running lights are on. Anybody know where the fuse is for that?
#142
If it's not in the trailer circuit, the only other choice you have is to start unpluggin harness plugs, or unplug other fuses one at a time. Unplugging harness plugs till the lights go out will give you a clue where the location of the problem is in the harness. Unplugging other fuses will tell you where the stray power is coming from, and that might give you a hint where to look.
#143
#144
#145
Ford E350 lights will not shut off.
Well Dave another satisfied customer! You are da man.
I found my issue tonight. After all the BS it was an aux plug behind the drivers seat. It has all the same color wires that go to the headlight switch. CORRODED! three pins were corroded together. My guess< Spilled BEER! Capping plug. Thanks everyone. See you at Crandon
#147
I don't know what model you are working on, but more than likely the tan/white wire is burnt in two somewhere between the switch and the fuse box. Double check the taillight fuse, that's where the tan/white comes from.
#149
#150
