'89 F250 No Fuel Problem
Old 01-23-2010, 05:11 PM
Tenderpaw's Avatar
Tenderpaw
Tenderpaw is offline
Hey guys,
My dad has an '89 F250 with a 460 engine and 120K miles. It isn't used very often and today I tried to drive it after it sat for about a month. It cranked but did not start. When first turning the key, I could not hear the fuel pumps start like normal. I'm suspecting its the fuel pump relay. Can anyone tell me where it is? There are several relays on the driver's side under the hood but none of them have a pink and black wire going to them like the manual says they should have. Also, the manual references a "test plug" to test the relay by grounding a connector. Is that plug with the relay? Any other ideas on what to check?
Thanks for your help.
Old 01-24-2010, 06:48 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
https://www.ford-trucks.com/forums/9...r-to-pump.html Have a look at this thread and the posts by subford on jumping the connector to test the relay.
dakota-boy
Electrical Systems/Wiring
03-14-2016 09:29 AM
PauL3861
07-19-2011 03:07 PM
deanna197
05-28-2011 08:21 AM
stirkrazy
01-11-2009 07:56 AM
900rider
06-02-2005 06:26 PM
Quick Reply: '89 F250 No Fuel Problem
