"55 F100 power brakes
It's likely I will go to disc in front eventually. I had a '56 longbed f100 for years, all stock and only had brake fade in extreme situations. Like Jose Wales said, "A man needs to know his limitations." I'm adding the booster to make braking easier, not to solve any problem with the system. Drum brakes are what they are.
Power boosters work well with drum brakes. If you want to reduce brake fade you just need to upgrade brake linings. For something this old, most auto parts outlets will only offer a "standard" lining material. If you want better, look for a place that relines truck and bus brakes, or a small to mid size industrial brake rebonder. There are some pretty decent brake lining materials out there that will make your drum brakes perform better than you would expect.
on
With that MC you are going to need 10 lb residual valves both front AND rear as that MC was probably made for use with four wheel disc brakes...
That is my plan. It looks like I will need to use a metering valve on the front also. I'll be looking into some premium shoes and also some sort of air vent design for the backing plates.
SeaSpriteGreen55
17
01-16-2015 08:46 PM
busted 55
08-26-2014 08:18 PM
stlouis55
05-21-2014 05:42 AM
Grey Ford
03-14-2011 07:48 PM
