cel
Old Jan 20, 2010 | 09:00 PM
jb65542's Avatar
jb65542
cel
i have a check engine light on and want to auto zone to get it checked. it come up with insuffecient egr flow. what do i do to fix this problem and would it cause it to miss under a load
it is on a 1996 f150 302 auto 4x4
Old Jan 20, 2010 | 09:05 PM
Hitokori's Avatar
Hitokori
yes it will cause it to miss and u can clean it i think or u can replace it
Old Jan 20, 2010 | 09:31 PM
rla2005's Avatar
rla2005
What was the exact error code? Your '96 most likely uses the DPFE style EGR sensor instead of the earlier version EVP. The DPFE sensor is more prone to giving false indication of an issue when there really isn't one. It would help to know the DTC number before making too many guesses of what might be going on
Old Mar 3, 2010 | 07:34 PM
mikebrawn1's Avatar
mikebrawn1
Not to jack the thread but I have the same hesitation under load problem and am getting a p0401 code. Kinda funny because it only does it when you first touch the throttle. All you have to do to get around it is just press the throttle a little bit more. It even does it in park if you rev is slowly and get to about 2000-2500 and it starts to rev up and down. Is this the dpfe sensor also? Thanks. 96 C-150 351w a40d.
Old Mar 6, 2010 | 11:09 PM
mikebrawn1's Avatar
mikebrawn1
Any help?
SUPERDUTY_08
6.4L Power Stroke Diesel
Apr 22, 2012 09:52 PM
skyoung
Oct 5, 2011 10:33 AM
ehgeeray
Jun 5, 2010 03:17 PM
Chip127
1983 - 2012 Ranger & B-Series
Feb 7, 2005 06:15 AM
ckstrawser
17
Dec 7, 2004 11:39 PM
